kl203p- new version ?
Mudslinger
Re: kl203p- new version ?
Post by Mudslinger » 13 Jan 2018, 20:03
I just run my fan from the power pack so that it is on all the time. It isn't any louder than the powerpack fan anyway. so it isn't an issue.
gmham
Call Sign: 108TM154
Post by gmham » 13 Jan 2018, 20:14
Ok perfect thanks yep as you say don't think it's much off an issue and have ordered a supposedly " silent fan " anyway ? Might use hexagonal pillars to mount the fan just above the heat sink , anyone else done this .. ?
.... Icom IC7300 HF /6 mtr
Kenwood TR751e 2mtr ssb
108-TM-154 - John
prettypolly
Call Sign: 26FB185
Post by prettypolly » 14 Jan 2018, 18:45
4 blobs of blutack works well
gmham
Call Sign: 108TM154
Post by gmham » 14 Jan 2018, 19:08
yep I know !!! just fancy doing it a more permanent way.. !
108-TM-154 - John
Mudslinger
Post by Mudslinger » 14 Jan 2018, 19:52
I used a couple of cable ties around the fan and amp.
It has been ok for 4 years so must be quite permanent.
gmham
Call Sign: 108TM154
Post by gmham » 14 Jan 2018, 22:27
Okay maybe permanent was the wrong word to use.. actually meant more professionally looking. !!
To be honest used the kl203 with the cable tie arrangement before and as you say does the job well. !!
108-TM-154 - John
Unit 148 Mobile
Post by Unit 148 Mobile » 07 Feb 2018, 13:15
WA10,
I just read this thread through and you took the words out of my mouth re the 550 and I've never run one!
The 1407 datasheet says it all: https://www.mouser.com/ds/2/453/sd1407-13154.pdf so two do not equate to half a kilowatt or anywhere close, that is unless it's over-driven and you add all the harmonic content :-)
IMO the very best thing one can do with most all amplifiers and not just the RM's is to drive them with 50% of what the manufacturer states for drive.
You get better reliability, a cooler running amp and a cleaner signal through lower intermod distortion however you won't get the "Worked all Neighbors" award with a wide covering half the band.
RM would probably sell a lot fewer amplifiers if you adhered to the above.
Unit 148 Mobile
ROTEL240
Post by ROTEL240 » 07 Feb 2018, 23:01
prettypolly wrote:
14 Jan 2018, 18:45
works well for me also and stops any fan vibration on the linear..
prettypolly
Call Sign: 26FB185
Post by prettypolly » 08 Feb 2018, 01:55
Or big rubber bands OK as well
wa10
Post by wa10 » 08 Feb 2018, 02:38
148
Its more appealing to believe the amp makers impossible ratings when the truth sound much less impressive.
Mitch
Post by Mitch » 08 Feb 2018, 11:50
I've always believed that a linears power rating was the INPUT watts i.e. how much power it uses, so a 300W amp will take 21 amps or so at 13.8v. I wouldn't expect 300W out. Sounds more likely imho. The sales copywriters take the highest number for the ads, obviously, being sales people, they like the bigger numbers. I wouldn't expect any better than 40% efficiency either so it kinda fits for me.
The perfect face for radio.
ghost123uk
Call Sign: 26TM953
Post by ghost123uk » 08 Feb 2018, 13:03
gmham wrote:
01 Jan 2018, 22:35
any idea what 10watts input would likely give out ?
ch25 wrote:
01 Jan 2018, 23:02
Square wave.
Image :thumbup:
andrew013
Call Sign: 26AT013
Post by andrew013 » 08 Feb 2018, 20:57
me and a mate run rm kl 500`s when the need arises his does 250 mine does 380 , tested off the same battery , radio , swr , meter and dummy load and we tested his first input power was 15 w, it was his battery so i dont know how charged it was , but i do know from my fully charged battery that still bubbles straight off the charger i get 450 plus out of mine for how long i dont know and all i did to mine was upgrade the power cable and fuse holder , brigded the 3 internal fuse holders and put 2 thicker cables on the board somewhere
and its not worth the while sticking 10 into a 203 its alot happier running with an input from 6to 8 watts or less if you want it to run cool
ghost123uk
Call Sign: 26TM953
Post by ghost123uk » 10 Feb 2018, 12:15
Don't mess about Image
EDIT =
OMG (as the kids say) Check this out {bnghd} :o
