Page 1 of 3
kl203p- new version ?
Posted: 01 Jan 2018, 11:10
by gmham
Guys anyone aware off any tech changes to the latest blue colored version off the kl203p linear over the older red version ?
Re: kl203p- new version ?
Posted: 01 Jan 2018, 12:32
by ch25
Same crap splatterbox.
Posted: 01 Jan 2018, 12:36
by gmham
ok cheers for your input !!!
Posted: 01 Jan 2018, 12:42
by mrpsychopath
Was told they are a lot better than the bv150s that i use. Had one of red ones before lasted 4 days till it popped. Hence why i now have bv150 splatterbox.
Posted: 01 Jan 2018, 12:45
by ch25
kl203 works acceptable as long as you do not exceed 2W AM/FM and 10-12 SSB on input. Looks not that bad on the scope and spectrum analyser.
More drive, more distortion. Tested by myself.
Posted: 01 Jan 2018, 12:48
by gmham
ok cheers
Posted: 01 Jan 2018, 13:35
by prettypolly
watch for the bf199 tranny pre amp goes pop if over driven ..
Posted: 01 Jan 2018, 14:05
by gmham
okay cheers so 12watts max on ssb input.
Posted: 01 Jan 2018, 14:08
by ch25
For longer talking I suggest to put 12cm fan on top of it.
Posted: 01 Jan 2018, 14:51
by Mudslinger
I normally put around 7 watts AM/FM and 18Watts SSB into mine and have had no issues.
Just be careful using it with a radio such as a PC-999 Grant, as they might give 8 watts on deadkey but with modulation power will rise high enough to hill the amp.
Posted: 01 Jan 2018, 15:07
by ch25
Mudslinger wrote: ↑01 Jan 2018, 14:51
You just have no idea of amout of garbage going out when you overdrive that box. Lucky, I do not have you in the neighbourhood.
Posted: 01 Jan 2018, 16:15
by Mudslinger
Well according to the specs I am not overdriving it.
No complaints yet, exept on one occasion a radio I was using had a fault.
I do use a reasonably good low pass filter.
Posted: 01 Jan 2018, 16:33
by 163TM847
ch25 wrote: ↑01 Jan 2018, 15:07
Finally, Someone who agrees with me that the KL203 [MOSFET] is an awful amp, Just by seeing the SWR jump when powered on indicates the amount of rubbish being spewed out of them, I dont have the pleasure of owning a spectrum analyser but i would love to see the results of a KL203 with 5-15w input.
Posted: 01 Jan 2018, 16:53
by Buick Mackane
I bought one new and had SWR Problems, Even with an inline filter, Personally i'd avoid them at all cost, They spew out more crap than spamdemon
Posted: 01 Jan 2018, 16:56
by ch25
Mudslinger wrote: ↑01 Jan 2018, 16:15
Specs given by rmitaly are pure b$. Similar to zetagi etc.
Black Spirit wrote: ↑01 Jan 2018, 16:33I dont have the pleasure of owning a spectrum analyser but i would love to see the results of a KL203 with 5-15w input.
I sold my analyser over year ago since I do not play with those toys anymore, but I still have a scope and when I get one of those boxes I will make some screenshots.
