Sirio Gainmaster newbie
mickymcd
Post by mickymcd » 08 Nov 2017, 12:16
Just purchased a sirio gainmaster to try will be using it on 11m mid band also 10m-12m is there any adjustments/mods etc to do on it before it goes up ? also what height do they work good at many thanks
Ur5by9
Re: Sirio Gainmaster newbie
Post by Ur5by9 » 08 Nov 2017, 13:41
Simple to build and has some recommended measurements to set the fibre glass poles. It will tighten together with jubilee clips and Id recommend some amalgamating tape to seal the joints and keep the water out.
Its a very long antenna and unsupported so it will flap around a lot which is quite normal. No tuning required it is pre set and very broadbanded.
As with any antenna the higher the better but do bear in mind as the antenna is unsupported the higher you put it the more its going to flap around. I recently tried one of these antennas but took it back down due to just how much it would fold its self over in the wind, it would go from being a vertical to a horizontal dipole and scary to watch.
As for performance it worked fairly well, although some of the regulars I chat to which are a bit further away said I dropped a bit signal in comparison to my Sirio 827.
ROTEL240
Post by ROTEL240 » 08 Nov 2017, 13:53
Good advice above, i will add mount on a long pole with some flex,i see people mount in on a 6ft pole on the side of the house and they snap in high winds because the SGM taking all the strain....
TheCaptain
Call Sign: 26TM669
Post by TheCaptain » 08 Nov 2017, 19:19
As above......seal the joints well and a good flexible aluminium pole.
Had mine up for years and years with no issues :thumbup:
"Wine for my men, we ride at dawn"
astradyne
Moderator
Moderator
Post by astradyne » 09 Nov 2017, 14:55
Mine's survived hellish batterings from the various storms that have hit the UK over the past few years. I bought it second hand, so didn't really know what it had had to handle previously. But it's stood up well to everything the weather's thrown at it, performs very well indeed, very low SWR, low noise floor and very good reports on DX.
I'd say a very good antenna.
NightProwler
Call Sign: 163TM186
Post by NightProwler » 09 Nov 2017, 19:39
I had mine up for about 4 years with no problems in the wind and an excellent antenna. It's now sadly lying behind my greenhouse looking very sorry for itself.
mickymcd
Post by mickymcd » 19 Nov 2017, 00:23
Early days but its got excellent ears low noise in fact keep checking to see if the things plugged in im hearing stations i couldnt hear before hopefully prop returns soon eh :)
Bigdave
Post by Bigdave » 27 Nov 2017, 08:20
Very good choice of antenna had mine up a good few years now,without any issues don't know if you went for 5/8th wave over the hw,heard of a few not to impressed with the hw,don't have the same bandwidth as the 5/8th...............................
26 -TM -1248
2E0ZON
The CT the waste man has spat his dummy out again. What a fargin ice hole he is.......... ...... :lol:
........... Often imitated, but never intimidated ..........
robber57
Post by robber57 » 18 Dec 2017, 08:52
Consider using two hoseclamps per section...
Bigdave
Post by Bigdave » 18 Dec 2017, 16:23
Twice the chance of over tightening it and splitting it,had no problems with one per joint........................
26 -TM -1248
2E0ZON
