New 11mtr vertical required ?
NUBSTER
Call Sign: 26TM545
Re: New 11mtr vertical required ?
Post by NUBSTER » 09 Oct 2017, 23:14
Did you wrap your swish curtain rails with wet string Dave ? , I've been told it works ....... ;)
Bigdave
Post by Bigdave » 10 Oct 2017, 05:37
No to be fair, but are give it a try thanx. Also read about swr grease I guess that's worth a try as well ........................
26 -TM -1248
2E0ZON
The CT the waste man has spat his dummy out again. What a fargin ice hole he is.......... ...... :lol:
........... Often imitated, but never intimidated ..........
kilimax
Call Sign: GM0BRJ
Post by kilimax » 10 Oct 2017, 07:27
Bigdave wrote:No to be fair, but are give it a try thanx. Also read about swr grease I guess that's worth a try as well ........................
Ah, the good old swr grease. Turns any old sh1te into a top performing antenna. Any respectable antenna fiddler shouldn't be without a tub. :lol:
Kilimax - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Post by MrWeetabix » 10 Oct 2017, 07:56
So them GMHam, what did you go for fella? :-)
gmham
Call Sign: 108TM154
Post by gmham » 10 Oct 2017, 10:02
Well as us Scotsmen are known to like saving the odd penny or two decided to save my dosh and put an old cushcraft r6000 20-15-10 mtr vertical into service that I had kicking around the garage, in the process off cleaning it all up before launch day !! hopefully it will work okay but if not the buy it now button on the sirio 827 is still flashing away at me !!!
.... Icom IC7300 HF /6 mtr
Kenwood TR751e 2mtr ssb
108-TM-154 - John
