New 11mtr vertical required ?
gmham
Call Sign: 108TM154
Post by gmham » 02 Oct 2017, 19:45
In the market for a new 10/11mtr vertical. Thinking off the Sirio 827 / Sirio 2016 etc.. any difference between the two ? Any strengthening mods required on them ? Anything else worth considering .. Tornado 27 new ?
.... Icom IC7300 HF /6 mtr
Kenwood TR751e 2mtr ssb
108-TM-154 - John
Call Sign: n0call
Re: New 11mtr vertical required ?
Post by ch25 » 02 Oct 2017, 20:10
2016 need strengthening of L shaped mast mount. Usually bend under a wind. Otherwise is a good antenna.
gmham
Call Sign: 108TM154
Post by gmham » 02 Oct 2017, 20:16
Okay cheers so might be better with the 827 ?
anyone here owned them both be interested how they compare performance wise ?
108-TM-154 - John
Call Sign: n0call
Post by ch25 » 02 Oct 2017, 20:21
I doubt there is anyone had them three at the same time, mounted at the same height to compare :) If not, it will be just guessing.
gmham
Call Sign: 108TM154
Post by gmham » 02 Oct 2017, 20:28
Yep sorry really meant between the 827 and the 2016..
108-TM-154 - John
Call Sign: n0call
Post by ch25 » 02 Oct 2017, 20:43
Hard to say.
When i test different antennas or tune them I use low power transmitter located circa 500m from antenna. Always same place, same height and power.
According to that test I can tell if one antenna is better or worst than the other.
mof000
Post by mof000 » 02 Oct 2017, 20:51
Oggy has just done a review of the Vortex quasar v2
https://www.youtube.com/watch?v=Uq0ulNbKlWo&t=75s
Call Sign: n0call
Post by ch25 » 02 Oct 2017, 21:04
Shallow review I would say. Similar results you can get by connecting curtain rail to radio.
The Collector
Post by The Collector » 02 Oct 2017, 21:54
Am I right in thinking that Shogun's RX wasn't quite right on the vid?
ROTEL240
Post by ROTEL240 » 02 Oct 2017, 21:57
Dont discount the cheaper sirio GPE27 5/8th wave its a well made cracking dx antenna
NightProwler
Call Sign: 163TM186
Post by NightProwler » 03 Oct 2017, 09:02
ROTEL240 wrote:Dont discount the cheaper sirio GPE27 5/8th wave its a well made cracking dx antenna
I'll second that. I put one up for a friend of mine a while back and the build quality is excellent :thumbup:
Oggy
Moderator
Moderator
Call Sign: M0OGY
Post by Oggy » 06 Oct 2017, 14:11
ch25 wrote:Shallow review I would say. Similar results you can get by connecting curtain rail to radio.
I would like to see your curtain rail.....shallow, Shallow Hal
European Citizens' Band (ECBF) Delegate For The United Kingdom
CB Radio .....The Firefly/26TM192
WARLOCK
Call Sign: 26TM134
Post by WARLOCK » 06 Oct 2017, 14:21
Usual ch25 statement shallow shallow as it is still at least this time he has put forward a better antenna in his mind HIS CURTAIN RAIL now all we need to know is where can we buy one from B&Q may be ???
Oggy
Moderator
Moderator
Call Sign: M0OGY
Post by Oggy » 06 Oct 2017, 15:51
WARLOCK wrote:Usual ch25 statement shallow shallow as it is still at least this time he has put forward a better antenna in his mind HIS CURTAIN RAIL now all we need to know is where can we buy one from B&Q may be ???
I look forward to his "Curtain Rail" review......maybe he will share a youtube link?.
Just maybe the CR special will match this antenna with just 3 watts of input....I wait with excitement. :think:
I see he has plenty to say when ever I get mentioned.
viewtopic.php?f=2&t=54062
Bigdave
Post by Bigdave » 09 Oct 2017, 16:06
I went for the swish curtain rail as it was more expensive, so it must be much better can't get the fecking swr down though........................
26 -TM -1248
2E0ZON
The CT the waste man has spat his dummy out again. What a fargin ice hole he is.......... ...... :lol:
........... Often imitated, but never intimidated ..........
Users browsing this forum: 14CS06 and 7 guests
