Best Linear for 27 MHz?
Unit 148 Mobile
Call Sign: G4ZOW
Re: Best Linear for 27 MHz?
Post by Unit 148 Mobile »
Tim wrote:In the specs for the KL-505 it gives the output power on SSB 'up to' 300W so that means it may just peak at 275 (ish). Like I said before, to get 500 or more out you need an HF linear.
Tim,
What what peak output do you think I should see from my 1500W amplifier?
Unit 148
Tim
Call Sign: 26AT239
Post by Tim »
Depends, what make is it? Is it solid state or valve? Output power will depend on what you put into it and without knowing the specs and put a good power meter that will read 2K between it and your antenna I couldn't make a guess.
JAFO
Call Sign: WR1Million
Post by JAFO »
I liked my Skipper 300 and recommend one highly. 600w pep when working tip-top, and due to the 1 driving 3 design, tends to provide the equivalent of RF speech processing on SSB for that extra punch!
- though they usually could use fresh tubes (8950, 6KD6*) and/or fresh high voltage supply doubler caps to get it up to spec.
It's also nice that it only requires about 12w-20w pep to fully drive it.
I would still have mine if it weren't for a local (dummy) CBer who wanted to swap for one, so I did and took home his Drake L4B, repaired the forty-cent HV lockout protection resistor he blew when he powered it up with the case open, and voilá, had a smart 1200w pep. :thumbup:
*Running 6v filament 6KD6 tubes require you series every 2 tube socket filaments, since the stock 8950 sweep tubes utilize a 12v filament.
