Mk1 Lincoln power leads
- Mudslinger
Has anyone got a link to where I can buy Lincoln Mk1 power leads for a sensible price?
The cheapest I can find is £9 which is a bit too expensive for what it is. (call me a tight arse if you like)
Re: Mk1 Lincoln power leads
I haven't seen them for cheaper than that .Mudslinger wrote:The cheapest I can find is £9
- Mudslinger
Well if I have to buy one that is fair enough, but if I could find out what the connector is called I am sure I could buy one and make one up.
I can't believe that type of connector is unique to the Lincoln. I would have expected it to have been used in a few non-CB applications as it doesn't look very special.
- NUBSTER
- Call Sign: 26TM545
I know Knights use to sell them but they recon they have none left and now discontinued, cos TBH I could do with a new one too
- porky.69
- Mudslinger
Thanks for the help guys.
I am sure I can sort something out, we may even have the correct pins at work.
- Mudslinger
http://www.ebay.co.uk/itm/6x-MX-19-09-1 ... OSwYvFZH6h~
http://www.ebay.co.uk/itm/10-X-MOLEX-02 ... xyiRlSa8B9
Not sure it is worth the hassle though.
Even if a few were made to sell on I doubt there would be much money to be made.
If the leads become unavailable though I am sure this may be helpful.
Just on this subject . What AWG is used on the Lincoln power leads ? It looks a heavier gauge than the normal power lead cable .
- Mudslinger
I think it is 18 AWG, 10 amps.
OK . Thanks Simon . I might buy some and make a few cables up . BTW The crimps you posted are the more expensive gold types . The tin over copper ones are a lot cheaper .
- Mudslinger
Thanks Sammy, will look for the other pins.
- Buick Mackane
http://www.ebay.co.uk/itm/10x-MX-5557-1 ... SwB09YDAOY
Or
http://www.ebay.co.uk/itm/2-Pairs-Molex ... Ciid%253A1
Or
- Otter
- Call Sign: 26TM439
- Otter
Hi Sammy, I am afraid you are mistaken. From the advert:cb4ever104 wrote:OK . Thanks Simon . I might buy some and make a few cables up . BTW The crimps you posted are the more expensive gold types . The tin over copper ones are a lot cheaper .
Contact Plating : Tin Plated Contacts
Contact Material : Brass
