Is there an adaptor to use 4 pin Mic' on Anytone 5555?
As per the subject field, does anyone know if these are available - and if so, please would someone be so kind as to provide a link?
Re: Is there an adaptor to use 4 pin Mic' on Anytone 5555?
The AT-5555 is a 4 pin radio. But if need Mike crossover cables try Knights
http://www.kcb.co.uk/shop2/contents/en-uk/d121.html
- ROTEL240
Yes knights will sort you out tell them what radio and mic you have and they will do you a crossover lead for around £10 posted I have has a few and they are very good.simonthewizard wrote:The AT-5555 is a 4 pin radio. But if need Mike crossover cables try Knights
Nice one for the link guys.
I will place an order with Knights imminently.
- andymuza
Just make one.
- Oggy
He maybe "CBA"andymuza wrote:Just make one.
Can you not just buy the correct plug and solder it on?
This ^Oggy wrote:He maybe "CBA"andymuza wrote:Just make one.
