New President
Oggy
Moderator
Moderator
Call Sign: M0OGY
Re: New President
Post by Oggy » 09 Oct 2016, 18:46
Some more 11 meter RX tests today :D
https://www.youtube.com/watch?v=IkA8Z2B ... e=youtu.be
Dave
European Citizens' Band (ECBF) Delegate For The United Kingdom
CB Radio .....The Firefly/26TM192
AShockwav
Call Sign: KE6LYU
Re: New President
Post by AShockwav » 27 Oct 2016, 12:39
Has anyone used the + version on CW yet?
Really like to know if that addressed the issue that all the others had.
73
Jeff
simonthewizard
Re: New President
Post by simonthewizard » 27 Oct 2016, 15:49
AShockwav wrote:Has anyone used the + version on CW yet?
73
Jeff
Ask direct that's easiest way groupe@president-electronics.com
My guess maybe, but certainly not sure at all. I've not considered using it at all on mine
73 Simon
LH27
Call Sign: TT
Re: New President
Post by LH27 » 30 Dec 2016, 21:25
Hi, I'm new here but this forum seems to be a good source to solve my problem :-)
Yesterday I got my brand new Lincoln II+ (xmas present to myself)
First impression is ok but but I was a bit disappointed that they have left out the 11m band, I have no plans to use it on that band but I had a plan using 27.555 as a monitor freq. to see if there is some possible activity on 10m, does anyone know if there is a mod for that ?
My second problem is that I'm not able to get the software from President to operate. I assume when connecting the radio to a Windows computer it will appear as a com port but there is nothing in my Device Manager.
I made a quick test and connected it to a linux computer and the dmsg commad show that the radio is connect but does Windows need any special comport driver ?
Lasse
Mudslinger
Re: New President
Post by Mudslinger » 31 Dec 2016, 18:02
There is a wire loop inside the radio which you need to cut which then enables 11m
Pretty sure the L2 isnt PC programmable unlike the other radio which share similar internals. (CRE-8900, AT-6666, DR-135UK etc)
kilimax
Call Sign: GM0BRJ
Re: New President
Post by kilimax » 31 Dec 2016, 18:35
Mudslinger wrote:There is a wire loop inside the radio which you need to cut which then enables 11m
I don't think the L2+ has the usual wire to cut but I may be wrong. I have one and I know it was modified by Knights before it left. It was not a wire as far as I understand.
Kilimax - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
Mudslinger
Re: New President
Post by Mudslinger » 31 Dec 2016, 19:23
Might just be a couple of button presses then like on the Alinco DR-135.
LH27
Call Sign: TT
Re: New President
Post by LH27 » 01 Jan 2017, 10:50
Thanks everyone, there is no wire to cut like I have seen on other Lincoln radios.
I have attached a picture showing
Regarding the programming via PC, there is a programming software for this L2+ and the President site but I'm not able to make the communication work so I have sent a mail asking if there is any special com port driver that is neede.
Lasse
recoil
Call Sign: 2e0myn
Re: New President
Post by recoil » 02 Jan 2017, 10:48
I use the lead for the crt9900/alinco 135 on mine .the drivers can be a pain sometimes just use the latest prolific one.
LH27
Call Sign: TT
Re: New President
Post by LH27 » 02 Jan 2017, 15:29
ok, so there is a special USB cable.... thanks
Lasse
LH27
Call Sign: TT
Re: New President
Post by LH27 » 02 Jan 2017, 17:32
Cable ordered :-)
But the next step now is to find out how to open it for 11m
Anyone ?
Lasse
Re: New President
Post by Admiral » 02 Jan 2017, 17:33
Maybe the programming will do it????
Mudslinger
Re: New President
Post by Mudslinger » 02 Jan 2017, 17:46
Might be worth emailing President?
It is probably a case of pressing a couple of buttons as you switch it on.
recoil
Call Sign: 2e0myn
Re: New President
Post by recoil » 02 Jan 2017, 17:53
its a menu option to open it up and a component inside radio that's how I did mine
Oggy
Moderator
Moderator
Call Sign: M0OGY
Re: New President
Post by Oggy » 02 Jan 2017, 19:34
I'm surprised that the cat hasn't been let out the bag yet on this mod.
