Moonraker Tornado Stinger Vs Sirio Performer 5000?
Gimpymoo
Call Sign: Gimpy
Post by Gimpymoo » 29 May 2016, 21:28
Hello all.
A total noob here, so learning as I go at the moment.
I currently have a mobile rig consisting of a CRT ONE N and a Moonraker Tornado Stinger 1.55m antenna.
My question is, with everything being equal, 2 mobile rigs communicating with each other with line of sight, would a Sirio 5000 2m offer any benefits over the Stinger assuming running at 4w. Is talk of the dark arts permitted here?
Thanks.
The Collector
Re: Moonraker Tornado Stinger Vs Sirio Performer 5000?
Post by The Collector » 04 Jun 2016, 13:24
They're 3 times as much for a reason :)
Would like one myself but will have to stick with my 49 pence CB-Line Sirio MIL copy thing for now.
Post by Admiral » 04 Jun 2016, 13:29
No disrespect intended, but in my humble opinion the Stinger antennas are crap, great for the 4x4 gang that want a mile max while churning up the mud at the weekend, but for general use they are rubbish.
Mudslinger
Post by Mudslinger » 04 Jun 2016, 17:40
I agree, springers are not all that great performance wise. The one I had I couldn't even get a decent SWR on.
A good cheaper antenna is the original modulator.
http://www.ebay.co.uk/itm/THE-MODULATOR ... SwstxVCrUC
andrew013
Call Sign: 26AT013
Post by andrew013 » 06 Jun 2016, 16:21
i dont often get very technical on here and i do hate stingers/springers types and i love sirio antennas (apart from that gain master) but both the stinger and 5000 are of the same design
coil at the bottom with a whip on top per say
the 5000 is a small coil very high power one i admit with very long whip and taperd and around 6ft 5 inch
the stinger bigger coil smaller whip non taperd but at 5 ft 2 inch its smaller than the sirio but not as small as the mini stinger piece of rubbish but its a decent size but have been known to rust quick , have bad swr etc etc and i certainly wouldnt want one over a sirio antenna from the high power /performer range if you can pick up a sirio 4000 cheaper get that instead as there is very little in performance between the 4000 and 5000 and the 4000 is longer again than the 5000 (only just mind, the 5000 trucker 3/8th is the tallest of them all) and the more you have in the sky the better in my book
height is might as they say
i drive with the 5000 3/8 on car and when i pull up static the 9 ft whip comes out and the differnce with 2+ft to a guy in holland 1s point and louder audio but thats dxing which is another story under different conditions
Mudslinger
Post by Mudslinger » 06 Jun 2016, 17:04
Normally antennas of similar length perform pretty much the same in the real world no matter where they are loaded, but for some reason the springers perform poorly for their size.
Maybe the open coil design messes up the radiation pattern? Also the SWR changes as you drive along due to the distance between the coils changing.
highvoltageuk
Call Sign: GM7TMW
Post by highvoltageuk » 06 Jun 2016, 18:31
Back in the mobile CB days we ofter used Scarlet Warrior, Red Warrior, Red Thunder, Red Devil....Ok for the price but dont leave them in the sunlight too long some bent like a banana :crazy:
Kenwood TS-680s
Maas DX5000 v4
Gimpymoo
Call Sign: Gimpy
Post by Gimpymoo » 14 Jun 2016, 08:28
Thank you for the replies.
Not disagreeing with any of you here as I am very very new to the hobby so am still learning, BUT.. I think being a little harsh on the cheap stinger :)
I have got 4 miles over not so flat, urban terrain to someone with another Stinger which I think is pretty good? My SWR is a 1.5 which is not too shabby?
Will be getting a 5000 anyway as having seeing one in person, they are the business, need a stronger mount though.
Also, thanks to Andrew, I did not realise the Trucker variant was longer so that has settled that.
I have to say though, for someone new to the hobby, I got the CRT ONE N, Stinger and mount for £70 and for the fun it has gave and performance, I could not have hoped for anything better relative to the price.
Post by Admiral » 14 Jun 2016, 10:51
If you want a decent mobile antenna then I recommend the AMPRO series from Moonraker. They have every flavour from 160-10 including an 11, but if you work a lot of UK40 then the 10 is better than the 11.
Despite your counter argument, I again suggest that the 'stingers' are crap.
beamer320i
Post by beamer320i » 14 Jun 2016, 11:00
I wouldn't say people have been harsh on the cheap stinger (emphasis on the word cheap), just reporting honest opinions based on actual use. For me, there is no comparison. I've used the same Sirio 4000 since 2002 and worked all over the world on it. They're not mega money and they do the job, very well.
Due to the size of the antenna, I do however recommend the heavy duty Sirio magmount (Sirio MAG 145)
I'm glad to hear your introduction to the hobby has been a positive experience, some people get set up and if they don't speak to anyone immediately just give up. Getting the 'right' set up takes time, experience (and money!) Bang for the buck, the CRT ONE N is getting rave reviews and is a great way into the hobby. Good luck and enjoy!
The Collector
Post by The Collector » 14 Jun 2016, 19:04
If you're going off-road then try and get the Sirio 165 magmount to suit, as the extra 20 mm diameter will help keep that 6ft beast in check.
I've given away 4 Springer/Stinger aerials and 2 magnets in the last couple of years but admit I still have an almost new one with a big magnet that I also got for pennies on ebay ...just in case it's needed if we have a Zombie apocalypse lol.
If I actually used a radio out and about I'd definitely go for a big Sirio ;)
Ossie12pints
Call Sign: 26aw085
Post by Ossie12pints » 03 May 2018, 22:37
Hi everyone. I'd just like to add what a fantastic antenna the stinger/springer is!
I've had two and the best one is from Moonraker with a straight whip as the thunder pole ones with a tapered whip are too short giving high swr on UK 40. The trouble is you can't make the whip longer. However the Moonraker with a straight whip is a bit long and with a little bit trimmed of the whip the swr is perfect. I had to cut about 1 inch off mine and get good contacts at 10 to 15 miles. Please remember no antenna is pre tuned!! You need to play about with them. Also if you want to run extra power an open coil is great for high wattage.
Farty
Post by Farty » 04 May 2018, 06:42
Ossie12pints wrote:
03 May 2018, 22:37
...except for the ones that are supplied pre-tuned...
radiogaga
Call Sign: 26TM399
Post by radiogaga » 04 May 2018, 06:59
Ossie12pints wrote:
03 May 2018, 22:37
Or the many enclosed coils designed for high power, ie 2kW
30TM399 Northern Costa Blanca
Mudslinger
Post by Mudslinger » 04 May 2018, 10:16
Have you compared the antenna to anything else?
Users browsing this forum: No registered users and 8 guests
