CRT SS6900 MIKE WIREING HELP NEEDED
- WARLOCK
- Call Sign: 26TM134
When wiring a mike up for a crt ss6900 radio do you leave pin 4 with no wire like you have to do on the anytone a5555 as i think the radios bare simlar.
- Mudslinger
Re: CRT SS6900 MIKE WIREING HELP NEEDED
The wiring is the same as President 6 pin.
- WARLOCK
mudslinger the crt ss6900 radio i have has a 4 pin mike socket not a 6 pin ?
- Mudslinger
OK it is the same as Uniden, but without the RX wire connected.
As you say, same as the AT-5555
I was getting mixed up between the 6900 and the 9900
- WARLOCK
Thanks Simon, i thought that was what you had done once again thanks.
from warlock---26TM134---Mr George from wisbech cambs,
- Call Sign: 163NLG48
Is this the same wiring for a sliver eagle.?
I was thinking of using the eagle on this radio but not sure if it would be to much ..
