Silver Rod Question........
GBHgpJON
Post by GBHgpJON » 19 Dec 2015, 17:00
Should I be getting continuity across the chasis socket on the above antenna, I would have thought this indicates an internal short? Bit of a newb when it comes to base antennas! :D
26TM095
26SWB014
Mitch
Re: Silver Rod Question........
Post by Mitch » 19 Dec 2015, 17:12
It's a short circuit at DC but at RF frequencies it's not, they've got a coil inside (like an unun), an RF transformer to match impedance and one side of that is grounded.
The perfect face for radio.
GBHgpJON
Post by GBHgpJON » 19 Dec 2015, 17:16
Right, it seems I may have been a bit premature in taking it down, after checking the coax for shorts while the coax was still connected to the antenna!
Back up the ladder tomorrow then!........Thanks for the info, still learning stuff.
26TM095
26SWB014
Dragonfly
Call Sign: 26TM363
Post by Dragonfly » 19 Dec 2015, 21:52
Loosen and retighten the screw that goes through the bottom antenna section into the top of the coil as this is usually the first thing to carode and go high resistance .
ROTEL240
Post by ROTEL240 » 19 Dec 2015, 22:06
GBHgpJON wrote:Should I be getting continuity across the chasis socket on the above antenna, I would have thought this indicates an internal short? Bit of a newb when it comes to base antennas! :D
Yes its normal, your coax or plugs seen to be at fault mate...
Post by Admiral » 19 Dec 2015, 22:08
Obvious question, but what's the VSWR like?
superstar
Post by superstar » 19 Dec 2015, 22:21
yes i know i'm a bit of a cb anorak, but its only a silver rod if its the genuine telex hygain silver rod from the 70's, none of this flimsy modern stuff is worthy of the name, yes its silver, yes its a rod but is it a telex hygain silver rod? naaa lol
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
GBHgpJON
Post by GBHgpJON » 20 Dec 2015, 00:08
Admiral wrote:Obvious question, but what's the VSWR like?
Never got that far, I'd just soldered the pl259 onto the end of the coax, and checked continuity, only to get a short. Disconnected the antenna and didn't have short, then checked antenna only to find continuity/short and wrongly assumed the problem was with the antenna.......shame I didnt ask on here before taking it down :lol: .........bottom self tapper should be ok as its brand new. ;)
It sez Silver Rod on the box.....thats good enough for me........ :thumbup: ;)
26TM095
26SWB014
Mudslinger
Post by Mudslinger » 20 Dec 2015, 09:56
If you have a DC short with the coax connected but not without then it sounds to me like everything is ok...
Oggy
Moderator
Moderator
Call Sign: M0OGY
Post by Oggy » 20 Dec 2015, 13:22
superstar wrote:yes i know i'm a bit of a cb anorak, but its only a silver rod if its the genuine telex hygain silver rod from the 70's, none of this flimsy modern stuff is worthy of the name, yes its silver, yes its a rod but is it a telex hygain silver rod? naaa lol
Your as bad as me :lol:
European Citizens' Band (ECBF) Delegate For The United Kingdom
CB Radio .....The Firefly/26TM192
Mudslinger
Post by Mudslinger » 20 Dec 2015, 14:03
The only "Silver rod" worth buying now is the Sirio one.
The rest are just flimsy rubbish.
GBHgpJON
Post by GBHgpJON » 21 Dec 2015, 12:35
Up and running now, :D SWR is 1.5:1 to 1.7:1 out of the box ....performance seems about the same as the inverted v in the loft, the (ahem) Silver Rods tip is bout 2m higher. Once the neighbours get used to the outside antenna I'll start to raise it up. :? Not much local stuff around anyway, so I may just stick with the v in the loft......time will tell :D Cheers for the help.
26TM095
26SWB014
The Collector
Post by The Collector » 21 Dec 2015, 14:44
Every extra foot up will pull more stuff in, so get hoiking ;)
GBHgpJON
Post by GBHgpJON » 21 Dec 2015, 15:36
:D Was gonna use the hoik word, but I reckoned people would be like....eh?? :eh: Now picking some local stuff that the v aint getting, so its looking hopeful!
26TM095
26SWB014
superstar
Post by superstar » 10 Jun 2018, 11:28
here’s a real one :)
Cb handle
Users browsing this forum: No registered users and 8 guests
