Anytone AT6666 microphone wiring
Queball
Post by Queball » 15 Dec 2015, 09:47
Just aquired one over the weekend but hate the standard mic. Can anyone tell me if the 6pin wiring is the same as the Lincoln/Grant 2. Are there also any live pins on there that i need to look out for too. Thanks for any information.
gholdq on youtube.com
26TM265
26FB165
26CT066
26UK165
astradyne
Moderator
Moderator
Re: Anytone AT6666 microphone wiring
Post by astradyne » 15 Dec 2015, 12:04
The Anytone 6666 is the same wiring as the Grant 2, Lincoln2, CRE8900, Alinco 135, Maxlog 8800/8900 etc.
Queball
Post by Queball » 15 Dec 2015, 12:20
Thanks Andy. Looks like a decent radio but just wanted to make sure before i put a CR577 on it or a Teardrop.
Thanks again mate.
26TM265
26FB165
26CT066
26UK165
astradyne
Moderator
Moderator
Post by astradyne » 16 Dec 2015, 02:23
Can't fault the one I have here (SS-9900 badged version). Sounds very well with a budget K-PO NM532 power mic on it.
Queball
Post by Queball » 16 Dec 2015, 14:56
It's not a bad radio especially now with a power mike. Ideal for going mobile
26TM265
26FB165
26CT066
26UK165
rabbiporkchop
Post by rabbiporkchop » 25 Mar 2017, 19:53
Does anyone know if it is ok to tie the source lead from the electret together with the transmit wire so they both connect to the shield or common wire when the button is depressed? I have the drain lead from the electret connecting to the audio wire when the button is depressed on another circuit.
I seem to have a sporadic feedback issue that mysteriously materialized after the microphone worked great for several weeks.
rabbiporkchop
Post by rabbiporkchop » 26 Mar 2017, 01:47
I fixed the problem. I put a .1 microfarad capacitor between the audio wire and the shield wire.
no more feedback
Eaglespro
Call Sign: KOM2139
Post by Eaglespro » 21 May 2019, 20:26
Anytone AT-6666
Stock & Power Mic
Pin 1 = White
Pin 2 = blue
Pin 3 = Red
Pin 4 = n/c
Pin 5 = Shield
Pin 6 = n/c.
I am working on up/down buttons for power mic
ramrezhe
Call Sign: 979RoadRuner
Post by ramrezhe » 12 Jun 2019, 20:19
did anybody know how to wire the up/down buttons?
