help and advice needed for a 75-100amp power supply
- Buick Mackane
Re: help and advice needed for a 75-100amp power supply
been having a look at server psu's. Seems like a lot of power for not a lot of money, Far as i can see from a quick bit of googling they need to have a few connections jumpered to power them on and a bit of fettling to quieten the fan and bobs your uncle, Think i'll jump on the bandwagon when it comes to this
- radiogaga
- Call Sign: 26TM399
I don't think they are generically that similar.PLL02A wrote:this might interest youradiogaga wrote:prettypolly wrote:one on for 15 quid
Got me one, do you have a link or plans for conversion?
http://www.transmission1.eu/viewtopic.php?f=34&t=47407
Holding out for prettypolly to come good with the details.
30TM399 Northern Costa Blanca
- prettypolly
- Call Sign: 26FB185
i only do dell 6850s as there silent and dont sound like a flipping jet engine ..ok here we go you need a 12 cm fan or 120 mm fan £1.99 of evilbay. in this mod theres no opening cases no vr pots no nothing its a plain simple get the wires correct and bingo 13.2 volts and 112 amps ..
- radiogaga
Good news, it's the 6850 I have and buy fluke a 120mm fan in the junk box...
- prettypolly
ill do a write up later as got the builders in at mo.
- radiogaga
Nice one... Thanksprettypolly wrote:ill do a write up later as got the builders in at mo.
- BaDBoY1985
- Call Sign: 223TM085
thank you for the help i bougt an ibm 2000bb 164 amp power supply
RANGER 69FFB4 I SIRIO GPE 27
sorry for the writing i am HUNGARYAN
- radiogaga
Sorry to pester mate, any news. I'm going to need a new PSU as mines is out on loan. Thanks
- prettypolly
xxxxxxxx
xxxxxxxx
OxxxxxxO
Oxxxxxxx
.... but first we must connect a fan to the opposite end of the psu ..first remove the plasitc white tag if it has one ..remove the aluminium black handle ..this must be removed its held in with an aluminium pot rivit drill it out gently ..then when done get hold of a 120mm or 12 cm computer fan and blue tack as a temporary measure stick the fan on the end of the psu squarely at the removed hand end ..warning you must position the fan which has arrows on it blowing out wards exhuastive extraction ..in english so its sucking air through the psu from back to front ..then we move to the other end attatch the fan wires to these terminals you have ten large brass copper terminals in a row of ten ATTACH THE WIRES NEG BLACK AND RED STRIPE OR A SOLID BLACK WIRE TO THE ANY LEFT TERMINAL AND POS RED WIRE SOLID RED TO ANY RIGHT TERMINAL EACH TERMINAL IS 13.2 VOLTS 25 AMPS ISH ROUGHLY
NEG II II II II II ---- II II II II II POSITIVE the left five are NEGATIVE CONNECTION AND THE RIGHT FIVE ARE POSITIVE PLEASE TAKE NOTE GET THIS WRONG AND IT WONT WORK ..now that you have the fan a attached to the terminals in the correct position ..hopefully you have done this correctly ..we must now attach the powering up wires please refer to the first diagram as follow the following set of instructions as provided
this is for the dell 6850 only 12 volt 121 amps server psu no other i take no responisility of it blowing up
connect the wires as directed on the diagram opposite O,s are on the left hand block 4 up and 8 across all wires must be connected together this is to power it up
i hope this is very clear but its the best way i can do it ..if it works fine if not contact me thank you.
xxxxxxxx
OxxxxxxO
Oxxxxxxx
- Buick Mackane
Found this onlineradiogaga wrote:prettypolly wrote:ill do a write up later as got the builders in at mo.
http://www.diyaudio.com/forums/power-su ... 1470w.html
oops prettypolly has already posted the info you are looking for
- radiogaga
Perfect thanks guys. I googled this for ages and didn't find anything -
- prettypolly
the pictures wrong it only has 6 pins on it across **the dell 6850 has 8 pins across ***
- radiogaga
Just seen that - So the switching is shorting of the O's or taking them to GND?
- prettypolly
no need for anything doing it my way don't even need to touch the PSU 121 amps for 1 hours work
- prettypolly
connect all the 0s together nothing else on that part
