Anytone At6666 Service Mode
mm3vee
Call Sign: mm3vee
Post by mm3vee »
Warning! Changing Settings in This mode can Cause Damage Or cause Problems' to your Radio!
If you don't Know what you are doing then Please don't mess with this menu!
Press Menu+Mode and you will Be in service mode!
Each Channel Has a hidden Menu! To get into each menu go to the channel and use the Push Chanel Button Quick Push Don't Hold
On my radio The BFO Control Is CH6!
your radio may be different!
I found this by mistake and didn't know I was in this service mode until I hade made changes to some settings!
now my receive is not as good as it was {bnghd} :wtf: !
Could someone please post the default menu setting's for each menu channel/Menu
Anyone willing to change the settings on the menus please note down the default settings before!
I have Made a Youetube video with some of the settings!!!
https://www.youtube.com/watch?v=ujb7TQ8M8YY
And be careful as you could mess up your radio
108EH002
Re: Anytone At6666 Service Mode
Post by 108EH002 »
That's why some prefer to buy new,if in doubt right the values down before you muck about with any menu inside a radio if you don't know what your doing at least you have a reference point to go back to,not aimed at you mm3vee but other's might be stupid enough to alter a perfectly good working radio when there is no need to ;)
27.555 Usb
Post by Admiral »
Would a factory reset not cure this?
mm3vee
Call Sign: mm3vee
Post by mm3vee »
No factory reset wont reset the settings..
have only get the rx meter sensativity to fix...
the BF0 is now bang on was easy enuff
Its easy to get into this menu by misstake as some of the menus have strange names..
wish there was a service manual with the default for each setting..
A quastion for anyone on this ridio
would someone post the default value for
ch-10 SQUL36
ch-11 SQUL01
ch-ch12 SQFA36
ch-13 SQFA01
This seems like the sq
but seems to effect the signal meter on rx sensativity.
if i could get the defaults from another radio would same me lots of time...
cjay
Call Sign: cjay
Post by cjay »
Why would you think they'd improve things?
The reason there's a service menu on these is to allow you to adjust *FROM* defaults to improve things.
Post by Admiral »
mm3vee wrote:No factory reset wont reset the settings..
Really???
Kaos
Post by Kaos »
ch-10 SQUL36
ch-11 SQUL01
ch-ch12 SQFA36
ch-13 SQFA01
Factory reset wont work.
Just had a look see on my AT6666 and I have different values from you.
If its like the Lincoln 2 which it might or might not be good luck in getting the setting that applied to YOUR set.
v4ticini
Post by v4ticini »
Did you found default values? or some meaning about that?
I have a problem with mine, when I transmit, my voice seems to be narrow and treble and other people can't clarify me well.
Macgiver
Post by Macgiver »
Press menu and mode at the same time. You have now entered service mode. Channels 1-3 do nothing. Access channels 4-17 by selecting channel then push on the channel selection knob. Exit channel by pushing menu.
Ch 1-3 na
Ch 4 freq 498
Ch 5 frq off
Ch 6 bfo 0556
Ch 7 afr 0626
Ch 8 ctcss 0039
Ch 9 DC's 0027
Ch 10 squl36 0810
Ch 11 squlo1 0013
Ch 12 sqfa36 0015
Ch 13 sqfad1 0014
Ch 14 asqon 0112
Ch 15 asqoff 0267
Ch 16 asc 0587
Ch 17 rssitx 0612
Ch 18 na
Cycle power off then on to completely exit this mode.
I don't know if every radio is set the same so this is just a reference as to my personal settings. I have not messed with them and do not currently intend to.
Audioshockwav
New User
New User
Call Sign: 2TM339
Post by Audioshockwav »
Old post I know, does anyone have the default settings for the CRT SS 9900V4?
Thanks.
73
Jeff
13EL121
Call Sign: 13DA121
Post by 13EL121 »
There are no default settings. Every radio has its own settings from the factory.
Audioshockwav
New User
New User
Call Sign: 2TM339
I just wanted to see what the numbers look like on the 9900 compared to the anytone 6666.
I fully understand that each radio is unique to its own settings.
My ft897d has the same style of service menu.
73
Jeff
tugafm
Call Sign: 351
Re: HIDDEN MENU Service Mode TEAM HAM-MobileCom 1011
Post by tugafm »
HIDDEN MENU Mode TEAM HAM-MobileCom 1011
CH1, CH2 e CH3 = nenhuma indicação
CH4 = FRQ-0498
CH5 = FRQ OFF
CH6 = BFO,AM, USB, LSB-0556
CH7 = AFR-0626
CH8 = CTCSS- 0039
CH9 = DCS-0027
CH10 = SQUL36-0810
CH11 = SQUL01-Ch 0013
CH12 = SQFA36- 0015
CH13 = SQFA01-0014
CH14 = ASQ-0112
CH15 = RSSITX-0612
CH16 = DTMF
