Alinco DR135 Software
mickymcd
Re: Alinco DR135 Software
Post by mickymcd » 08 Dec 2014, 13:24
Orderd my anytone cable where does it plug into on the pcb of the dr-135dx ? thx
delboyonline
Post by delboyonline » 08 Dec 2014, 13:37
mickymcd wrote:Orderd my anytone cable where does it plug into on the pcb of the dr-135dx ? thx
Open the radio.
With the radio upside down and front facing towards you.
You will see a cable which runs from the back right hand side of the radio to the front right hand side. At the end of the cable a 4 pin connector goes to the board.
Remove the cable from the connector at the front of the radio.
The anytone connector only has 3 pins and it connects to the 4 pin connector in such a way that the pin nearest the front of the radio isn't used.
Dragonfly
Call Sign: 26TM363
Post by Dragonfly » 08 Dec 2014, 14:47
I think you have to save each one of the UK 40 separately to get the 125 on the end of the frequency . My mate is allways programing these Anytone types and he said they wont program en block .
Mudslinger
Post by Mudslinger » 08 Dec 2014, 15:54
The DR-135 doesn't work in the same way as the AT-5555 in terms of manual programming.
On the AT-5555 if you change the frequency manually the radio will remember it when you leave the channel and go back and it only affects one channel at a time.
On the DR-135, if you adjust the frequency up to end in 5 manually, the radio will go up by that 5 on every channel, even on different banks.
I just left mine with the channels ending in 20 as it was less hassle and I couldn't tell any difference anyway.
Triple3
Post by Triple3 » 08 Dec 2014, 15:58
When entering frequencies in the software, I couldn't see a way of populating a list and a simple cut & paste was not possible either.
I had to enter each one separately.
Very basic and looooong winded software, unless there is a short cut?.
delboyonline
Post by delboyonline » 08 Dec 2014, 18:14
Cable Connector:
Quick way to populate the channel list in the software:
Click "SETUP" then "INITIAL SETTING"
Triple3
Post by Triple3 » 08 Dec 2014, 20:13
Initial setting population is ok if you want to start at a frequency governed by the software.
It doesn't seem like you can customise this in anyway.
mickymcd
Post by mickymcd » 09 Dec 2014, 00:18
Cheers del ill await my cable hopefully tmw :clap:
cjay
Call Sign: cjay
Post by cjay » 09 Dec 2014, 20:13
Pfft....
Cables be damned, a Bluetooth adapter is the way to go:)
mickymcd
Post by mickymcd » 10 Dec 2014, 12:40
Help :oops: what have I done or not done got the lead today plugged in driver come up ok com port 5 connects to radio ok I got a dat file off lad I know written it to the radio but when I power it on it just reads 28mhz everywhere {bnghd} feck
andymuza
Post by andymuza » 10 Dec 2014, 12:49
What frequencies did the dat file cover?
Was the radio in band 1 or band 2 mode?
Try rewriting the file to the radio.
Road_Hog
Banned
Banned
Post by Road_Hog » 10 Dec 2014, 12:54
mickymcd wrote:Help :oops: what have I done or not done got the lead today plugged in driver come up ok com port 5 connects to radio ok I got a dat file off lad I know written it to the radio but when I power it on it just reads 28mhz everywhere {bnghd} feck
You obviously saved an original copy from your rig before you started playing, didn't you? And then you just load that file back up.
Oh, you jumped straight in without saving a copy and now you've royally fcked it up?
andymuza
Post by andymuza » 10 Dec 2014, 12:54
If all else fails, turn the radio off.
Hold FUNC and SCAN at the same time and power on the radio.
Let go of FUNC and SCAN and RES should appear in the display.
Turn the radio off and back on.
andymuza
Post by andymuza » 10 Dec 2014, 12:55
It's not fcked up at all. It will be fine, stop trying to scare him ;)
mickymcd
Post by mickymcd » 10 Dec 2014, 13:01
:oops: YEP I JUMPED STRAIGHT IN ! arghhh it wont reset back to how I got it the dat file I have is ok few people I know of are using it the radio was in 11m mode when I programed it all I get at the mo when connecting radio to pc is frequency band is wrong and all I got it 28mhz everywhere on radio :oops:
Users browsing this forum: No registered users and 8 guests
