Lincoln 2 or grant 2 which is the better performer?
108EH002
Re: Lincoln 2 or grant 2 which is the better performer?
Post by 108EH002 »
I usually just change to a smaller tuning step,when I am close enough to the required frequency spyder3,but I know what you mean for ssb freebanding.
27.555 Usb
108EH002
Post by 108EH002 »
spyder3 = I found the L2 works far better on ssb with memory mode off,set to FR in the menu and press mem for a few seconds for store,with the channel change/vco depressed and the required step chosen,you can use the up/down buttons on the mic/CH up and down on radio/ch change/vco,and this makes the L2 far better than going up/down in steps ending with a 0 or 5 like the G2.This makes the L2 a better radio for what I want a CB to do ;)
27.555 Usb
spyder3
Call Sign: 767
Post by spyder3 »
Thank you,
I’ll try that.
I like Lincoln-2+, not so much noise compare to Grant-2, variable output power allows me to transmit from a few watts up to 450W on SSB (Texas Star 500). Good radio.
Actually there is no long range propagation here, US stations only. The last good QSO was a couple of months ago with 3SD100 on 27.555 USB.
No Europe, no Brazil – just N Carolina, Florida, Ohio etc on 27.385 LSB :(
9SD767
President Lincoln 2+, Sirio Performer 5000
QSO: Spain, Curacao, Holland, Mexico, Columbia, Salvador, Puerto Rico, UK, USA, Jamaica, Brazil, France, Italy, Scotland, Germany, Poland, Saint Lucia, Portugal, Austria, Sweden, Finland, Paraguay, Dominica, Uruguay, Santa Cruz, Ecuador
108EH002
Post by 108EH002 »
Once the L2 is set up spyder3,it goes through the frequencies more like an hf set does,when using the up/down Ch change buttons on the mic,for each tuning step required,my L2 out of memory sits on 27.555 ;)
Not hearing much long dx at the moment on ssb,mostly Eu,but the short skip into 26/29/68/163 was running last few day's,29 on Ch19 Ukfm last night.Usually 1/13/14 heard here the most on Ssb.
27.555 Usb
Adidas SoulBoy
Post by Adidas SoulBoy »
108EH002 wrote: 15 Aug 2018, 06:59 The L2 I use has 27.781.2 Fm,27.555 Usb,27.385 Lsb,27.315 Fm,27.275 Usb,27.025 Am,stored into the memories,and I just use the channel change/vco to get either side of each frequency/mode stored.I only use 10m radios on 27MHz CB,so it works fine for me ;)
Hi how did you manage to save 27.7812 in your lincoln, mine saves as 27.785
108EH002
Post by 108EH002 »
You have to change the setting in the menu from CH -(channel) to FR - (frequency) and store,and you can adjust the frequency using the span line under each of the digits that can be changed.
27.555 Usb
Adidas SoulBoy
108EH002 wrote: 30 Oct 2019, 15:32 You have to change the setting in the menu from CH -(channel) to FR - (frequency) and store,and you can adjust the frequency using the span line under each of the digits that can be changed.
Hi mate, i done that already and it still wont save as 27.7812 it may be the lincoln 2 plus
108EH002
Post by 108EH002 »
Sold the L2 V3 at the start of the year A.S,so don't have one infront of me to tell you how I done it.
But it is possible as I done it with a V1 aswell.
If you take the radio out of memory mode and change to FR in the menu,you will achieve frequencies ending in more than a 5 or 0 ?
If your radio is a + it will be on the front above the screen.
27.555 Usb
Adidas SoulBoy
108EH002 wrote: 31 Oct 2019, 13:15 Sold the L2 V3 at the start of the year A.S,so don't have one infront of me to tell you how I done it.
hi bud yes you correct i done that , now im just trying to save it into one of the 6 memories and it saves as 27,7850 instead of 27.7812 when it has saved in the memory. i do appreciate your help
