My new RCI 2950DX has a 7amp fuse fitted , where the heck can i find replacement fuses does anyone know , only one's close to 7 amp i've found are from maplins and they are only 6.3 amps , only asking as i'd like to take the rig mobile .. also does anyone know where to buy 12 amp fuses from ? for the kl500 , what size fuse should i drop inline for running this mobile or homebased..
please dont say i can find em on fleebay as i dont like paying for stuff via paypal as i've had probs with paypal in the best and would never use em again..
RCI 2950DX 7amp fuses ?
- Call Sign: 26TM057
- ScotchEgg
- Call Sign: 26TM742
RE: RCI 2950DX 7amp fuses ?
The KL500 is rated at 34A but check the specs as it will tell you what size are fitted internally. Try Truck king or Knights for the correct replacement fuses. Or any other radio retailer I guess. hth.
The legend of the "Scotch Egg".
"unique in my duplicity"
UGLY BOB on SCOTCH EGG... "I kinda had you pictured as the sort who would enjoy beating the bejesus out of people with a four foot dildo."
3 x 12amp fuses internally in the kl500.... so might a 30amp work for mobile use if not used on full power ? i'm sure i read it somewhere on the forums here.. looks like i wont be going mobile in the morning then to see if i can get some of the irish TM's .. oh well unless i take the superstar 3900 out as that only has 10amp fuses and i can get spare for that no probs... loool
ok thanks for the help Callum...
- Banned
the proper fast blow 7amp fuse for your ranger 2950: http://shop1.actinicexpress.co.uk/shops ... d_Fuse_Box
up too level 4 a 30 amp fuse should be ok.the worst that will happen is the fuse will blow.
Banned Account
ok thanks jazzsinger , currently i have some 6.3amp fast blow fuses inline for the mobile setup they seem to be fine , so i guess i'll stick with them.. I'll try the 30amp fuses when i sort the battery for the linear..
All the best ..
Ian...
after thought.. i cant find any retailer that does the 12amp fuses for the kl500 , TK sent me some 15's (???) best hope i dont blow the internal one i guess, also contacted the mf and they gave me someone else to contact in the uk but they dont deal with end users..
All the best ..
Ian...
