Tristar 515M
Ashtec
Call Sign: M6LTD
Re: Tristar 515M
Post by Ashtec » 07 Feb 2015, 19:02
This radio is based on the Stag 357 40 channel CB radio with the (LC7120 PLL) the 10.240MHz Ref divider Xtal is removed & a Very simple single JFET variable frequency oscillator is wired in the 10.240MHz Xtals place. The HI & LO band frequency is done by the PLL's program pins. The VFO knob drives a planetary gearbox to give slow motion drive that is connected to the VFO's variable capacitor. The frequency counter takes its input frequency from the VCO to a Mixer FET were mixed with 7.800MHz. The 7.800MHz IF frequency is taken away from the VCO output frequency and the frequency thats left is displayed on the LED frequency display of the radio sadly there is no SSB off set frequency that is displayed on the counter but the counter is dead on in AM-FM mode.
The C displayed stands for clarifier & the U displayed on the display Stands for Modes ie. U for USB mode. A for AM mode. F for FM mode. and L for LSB mode.
bernado
Re: Tristar 515M
Post by bernado » 10 Feb 2015, 03:32
Good Morning!
I'll get one more time to speak!
I have my Tristar now equipped with a DDS VFO!
She is now very stable frequency!
The frequency counter now shows the correct frequency, ie, AM-FM USB LSB all the same!
Even a decent FM module has been inserted!
The area is about 26-28 MHZ!
The unit runs great!
The frequency counter you can get at Maurer from Austria, you just have to shrink the segment displays!
Also the FM module you get there!
mfg
Bernd
14CS06
Re: Tristar 515M
Post by 14CS06 » 10 Feb 2015, 12:10
Hello
Tristar 515M on Ebay
http://www.ebay.fr/itm/CB-Mobilfunkgera ... 1c4de95622
Ashtec
Call Sign: M6LTD
Re: Tristar 515M
Post by Ashtec » 10 Feb 2015, 17:08
bernado wrote:Good Morning!
mfg
Bernd
Interesting there bernado i my self have not played with any dds VFOs as of yet im a bit old school is the any chance of some pictures of your DDS radio?
bernado
Re: Tristar 515M
Post by bernado » 10 Feb 2015, 22:04
Good Evening!
Yes, it is possible in the near future!
My girlfriend took my camera on holiday!
If she are back again, I can take photos!
It must be mounted because the output power is too low nor an amplifier for the DDS module!
I have long been used in order to gather these findings, because none of the people which information is to know!
It can now actually each CB unit rebuilt!
You've also another VFO installed?
Ashtec
Call Sign: M6LTD
Re: Tristar 515M
Post by Ashtec » 11 Feb 2015, 18:51
bernado wrote:Good Evening!
Interesting ive had a good look about the internet today about DDS conversions to radios and it dose look simple to say building a Analog VFO.
I take it your using the AD9850 or AD9851 Generator module to feed the vco or are you feeding it to the 10.240MHz Ref divider pin of he PLL keeping the PLL?
bernado
Re: Tristar 515M
Post by bernado » 15 Feb 2015, 03:28
Exactly that's all!
Quartz out and DDS connect!
It must be a sine wave signal with high output power of about 3 - 4 volts!
bernado
Re: Tristar 515M
Post by bernado » 15 Feb 2015, 03:37
My next project is a President Adams to rebuild with DDS VFO!
Iam searching for a suitable frequency counter for that! I do not want to rebuild my original Adams VFO for it!
cjay
Call Sign: cjay
Re: Tristar 515M
Post by cjay » 15 Feb 2015, 11:29
Replace the offset crystals with the DDS signal, step it in 5KHz increments for Cybernet, 10KHz for Unidens, works a treat. I've added a cheap AD9850 module to a Lafayette 1200FM and it works really well.
Of course you can step in larger or smaller increments and FM needs to be applied to the VCO instead of the offset crystal (FM modulating a DDS takes some serious coding and processor power but is possible)
This:
https://www.youtube.com/watch?v=9lXaof9owww
https://www.youtube.com/watch?v=sMemJouive8
Is my code and project which I must get 'round to finishing.
As Bernado says, you may need a buffer stage to raise the output and there's no reason to limit yourself to 5 or 10KHz steps, you can step in MHz or less than 1Hz, the only reason I started there was to make the radio stick to the CB channel spacing.
Ashtec
Call Sign: M6LTD
Re: Tristar 515M
Post by Ashtec » 09 Jun 2015, 19:06
Thanks there cjay i did read your post some time back as well as watching your vids on your project DDS but forgot to repost back on this subject...
I did get all in to Modifying my Realistic TRC448 with DDS and brought a UK made DDS kit but that was put aside to make my own DDS unit with LED display read out but then Summer came so the lot's been put away for winter as now the suns back out im back on renovating the house...
Ashtec
Call Sign: M6LTD
Re: Tristar 515M
Post by Ashtec » 24 Nov 2015, 12:59
bernado wrote:Exactly that's all!
What Buffer amp did you have to build to get an out put of 3 - 4 volts bernado...?
Retro_CB_Dude
Re: Tristar 515M
Post by Retro_CB_Dude » 08 Jun 2017, 00:30
Ashtec I'm sending you a private message please respond ASAP thanks 73's !
mof000
Re: Tristar 515M
Post by mof000 » 08 Jun 2017, 20:18
He hasn't been on here for quite a while. That said he may get an email about your PM?
speeddemon
Re: Tristar 515M
Post by speeddemon » 14 Sep 2017, 21:40
Hello to all does anyone have a schematic or service manual for this.. ?
14CS06
Re: Tristar 515M
Post by 14CS06 » 15 Sep 2017, 16:19
speeddemon wrote:Hello to all does anyone have a schematic or service manual for this.. ?
Hello
Please look at this link
Electronica SS 701 (same as Palomar SSB 500 ou Universe 5500)
http://www.funkbasis.de/viewtopic.php?f ... 26b5a33ef1
