Adding CEPT to an Audioline 340/341
Hi, apologies if this is in the wrong forum area but how easy is it? I can't find any online guides but someone has given me a 340 and 341 for free and I fancy playing about with them.
I was last on CB in the early 90s and added cept to some Rotel 240s and York 863s so I have some idea of what I'm doing but of course it's coming up to 20 years since then.
TIA
TIA
- 163TM847
Re: Adding CEPT to an Audioline 340/341
there seems to be a few floating aroud on fle bay reasnobly priced dunno if there genuine article or not as been obsolite for a good while
- 163TM847
I forgot until someone else sent me a msg earlier, That there is some info missing for the Mid block conversion on the link above..
You also have to cut the trace going to pin 4 on the TC9119 PLL and solder a piece of wire from the trace you just cut and run the other end to pin 1 [Pin 4 is left blank]
Without this the mod wont work.
I bought 2 of them of ebay i put mid band in a audioline 340 it seems to work okwizzer2k wrote:there seems to be a few floating aroud on fle bay reasnobly priced dunno if there genuine article or not as been obsolite for a good while
thats good to know that
I now have mid banded a uniace 300 and that is working fine to so i would say them PLLs are okludwig wrote:I bought 2 of them of ebay i put mid band in a audioline 340 it seems to work okwizzer2k wrote:there seems to be a few floating aroud on fle bay reasnobly priced dunno if there genuine article or not as been obsolite for a good while
I've just down this mod and it works great but the power from channel 35 below on the mid band drops until i get to channel 1 where it's a 1/2 watt.
Is that normal ?
Is that normal ?
Have you retuned the final stage ? I presume it'll need adjusting .
Tried it won't go any higher.cb4ever104 wrote:Have you retuned the final stage ? I presume it'll need adjusting .
It might need some components changing (Capacitors/Inductors) . I don't know what the final stage is like on those radios . Nick (Black Spirit) will no doubt know how narrow banded they are .
Could be a LPF issue, some are tighter than others.
It don't matter as there is no one on anyway lol.
