FM Interference
scanhermit
FM Interference
Post by scanhermit » 11 Dec 2016, 20:45
Anyone heard of a neighbour's heating timer causing crackling on FM? A poster on a non-scanny forum is asking. The crackling starts about 8:00 and ends at 20:16 every day so suggests a heating system. Or does the jury know of any other timed device/system that would do this?
WeatherWatcher
Re: FM Interfeence
Post by WeatherWatcher » 11 Dec 2016, 20:52
What FM frequency, Time span - is neighbour a commercial or domestic property.. Possible if commercial could be a wi fi network, catering could be dodgy stats on ovens etc.
scanhermit
Re: FM Interference
Post by scanhermit » 12 Dec 2016, 05:50
Radio 4, so around 93-94mhz. He is surrounded by housing with a longstanding woodworking workshop. Industrial units hundreds of metres away, railway station ditto.
The crackling is fairly even and worse where the FM signal is weak. He is suspecting some Christmas contraption in a neighbouring flat.
Tim
Call Sign: 26AT239
Re: FM Interference
Post by Tim » 12 Dec 2016, 09:44
The cause is most likely to be from the transformer that powers such things as LED security lighting, computer and other charger units, it's RFI generated by these cheap transformer units, see if the noise is there across the other bands as well. The only way to really cure this is for the item that's causing the problem to be put in the bin and replaced with one that is guaranteed RFI free.
Re: FM Interference
Post by Admiral » 12 Dec 2016, 11:30
If the interference is coming from a 3rd party then your correspondent needs to contact Ofcom.
scanhermit
Re: FM Interference
Post by scanhermit » 12 Dec 2016, 18:33
Many thanks, all. I've passed your suggestions along. I'm glad I'm not him.
troffasky
Re: FM Interference
Post by troffasky » 06 Jan 2017, 22:55
Cheap LED bulb I put in the cooker hood did this. Ended up in the bin.
