how to improve DAB reception
The place to discuss long distance TV and Radio Reception. Equipment, Antennas and anything to do with the art of DX.
owza
Call Sign: 2E0
Re: how to improve DAB reception
Post by owza » 02 Nov 2016, 14:03
>DAB is rubbish, its ok if you want to listen to mono MP2 quality "Digital" audio at home. It gets even worse if you have one >on the move like in the car or have one portable.
There are a few DAB+ stations out there now, using slightly better aacPlus
scanhermit
Post by scanhermit » 11 Dec 2016, 21:01
Just bought a Roberts DAB radio/CD player/USB & SD player. The signal is great and the sound quite nice and clear. I have used a car with DAB and analogue before. I was driving around rural Aberdeenshire and there where bits where DAB staccatoed like a **** and I had to switch to analogue.
I've got analogue on my big stereo and my Tecsun PL-660 so I'm sorted either way.
Farty
Post by Farty » 11 Dec 2016, 22:53
DAB could be acceptable at max quality, but they ram so many channels onto each doobrey that the bit rate cuts right back and it ends up flat and dull sounding.
scanhermit
Post by scanhermit » 12 Dec 2016, 18:56
Well, I'm not sure they needed to do it beyond "Hey, this is new, analogue is old and new is always better". I hear it chews more power too.
However, I've decided to cover both bases in case the f****rs switch off analogue.
Tigersaw
Call Sign: G6RRL
Post by Tigersaw » 12 Dec 2016, 19:22
To answer OP. Someone gave me a stack system DAB, and it has an F type input.
I made a J-pole for 220Mhz, choke at the bottom and checked it with the analyser.
Its much bigger than the crappy dipoles they try and sell, and mounted vertical I get 50+ radio channels, all with no bit errors. Sounds OK, though I only listen to radio2/4 on it after all that.
Tim
Call Sign: 26AT239
Post by Tim » 14 Dec 2016, 15:37
We will never get any DAB reception where I am, when the analogue TV was switched off it was said that there would be no more co-channel interference or dropping out of the signal, well, that was a bloody lie!, when we have high atmospheric pressure we get a black screen with a box in the middle with blue script saying 'channel not available' or 'no signal'. We were led to believe that digital services would not be problematic.
scanhermit
Post by scanhermit » 05 Jan 2017, 18:55
Norway is about to switch off FM and the bulk of Norgys isn't too gruntled over it.
https://www.theguardian.com/world/2017/ ... f-fm-radio
troffasky
Post by troffasky » 06 Jan 2017, 22:53
Farty wrote:DAB could be acceptable at max quality, but they ram so many channels onto each doobrey that the bit rate cuts right back and it ends up flat and dull sounding.
BBC Music Jazz popup station in November. 64kbps mono. Unlistenable.
stratocaster
Post by stratocaster » 12 Jan 2017, 08:58
Best if you can get a DAB+ compatible receiver then you can listen to Jazz FM, lower bit rates, but better sound quqality than standard DAB only just!
troffasky
Post by troffasky » 12 Jan 2017, 21:26
The only reason I've got the DAB radio I have is that one of the neighbours left it next to their bin...yoink! I certainly wouldn't pay for a DAB radio. There's nothing on DAB I would listen to [apart from a 1-week-a-year station] that isn't on FM.
Black_Pirate
Call Sign: 26TM034
Post by Black_Pirate » 20 Apr 2017, 16:42
weird though it is.........low reception is improved in my solid brick office by.......wait for it...a bulldog clip ...A large 3/4 inch one of course....clipped to the end of the antenna....
see you on Dragons den as its not copyright.obviously if your near a window,thats best.
but having fun on the radio.........
RoS beacon on 27.635 with propagation :-)
26T.M.034
GOOD LUCK IN DX
