Can,t DX on 11
Can,t DX on 11
Just back to DX after a long spell off and was enjoying a few contacts but it seems a local Amateur who has all the exams and licencse,s is intent on keeping people from dx'ing . He transmits a constant key up on 27.555 but on fm with a very low output so it only blocks the local area at about a 20+ signal which bleeds into 27.535 to 27.585 so all incoming dx can,t be heard . This goes for days on end but very occaisionally is turned off , but today is a sunday weather is great looking forward to some DX but can't !!! Any Ideas
- bigpimp347
Re: Can,t DX on 11
find out who he is and report him to illegal transmitting on 11mtrs..!!
there are other bands you can use 26.285, mids etc..
if he is causing that much trouble he must be close, and if it's 20db and using low power he's a neighbour.!!
- George EI7KO
- Call Sign: EI7KO
Re: Can,t DX on 11
Find out where he is and push a needle through the Coax and short it out. After an hour or so problem solved....
BLUE LED'S ARE BEST!!!!
Re: Can,t DX on 11
Dare I ask an obvious question... How do you know he's an amateur? If he is, do you know what's triggered this response/behaviour? Seems a bit OTT for someone to do.
Personally, I would think the most an amateur would do is listen. To go out their way to block the frequency with a low level carrier seems rather strange.
Perhaps there is more going on here than meets the eye (or ear)...
- 26CAB40
Re: Can,t DX on 11
Bear in mind that his carrier will not stop other stations abroad hearing your call.
So just include a QSY frequency in your call.
Simples.
Simples.
"It's worth whatever they're willing to pay"
Re: Can,t DX on 11
Just go onto 27.385 LSB the States are in again.
gholdq on youtube.com
26TM265
26FB165
26CT066
26UK165
26TM265
26FB165
26CT066
26UK165
- Adriano9966
Re: Can,t DX on 11
sounds like a charming character ..I would say go mobile he cant touch you then if you drive a few miles out of the general area
Re: Can,t DX on 11
Yeah that works got a couple of cotacts today , just called out and moved to 515 , Thanks for the input everyone .26CAB40 wrote:Bear in mind that his carrier will not stop other stations abroad hearing your call.
Simples.
- Custer
- New User
- Call Sign: 2TM101
Re: Can,t DX on 11
I will be listening for you then.Queball wrote:Just go onto 27.385 LSB the States are in again.
Re: Can,t DX on 11
the eu cb channels from about 27.185 to 27.325 on AM . 27.335 to 27.405 on LSB your hear the USA at the min . good luck
73
dave
73
dave
