Sorry me again ok ive been thinking about antennas for a static mobile set up, ive been given a couple of whips and the bits to conect them to make a dipole, for some reason (and i dont know why) im thinking horizontal might be a good idea for dx? is my random thought right? i dont know where it came from lol have googled around a bit and found people use horizontal and vertical as well as v shaped for 11m dx, what would your recomendations be?
Many thanks
Matt
horizontal and vertical antennas?
Re: horizontal and vertical antennas?
Hi Matt, it depends on the band.Retic wrote:Sorry me again ok ive been thinking about antennas for a static mobile set up, ive been given a couple of whips and the bits to conect them to make a dipole, for some reason (and i dont know why) im thinking horizontal might be a good idea for dx? is my random thought right? i dont know where it came from lol have googled around a bit and found people use horizontal and vertical as well as v shaped for 11m dx, what would your recomendations be?
Many thanks
Matt
If you are working Troposphere propagation on 2 Metres then Horizontal polarization is what most people use.
The benefits of Horizontal polarized antennas are that you will be less susceptible to QRM from Vertical polarized stations and noise, with regard to HF (27 MHz included) and 6 Metres it is purely optional as when your Radio signal arrives in the Ionosphere its polarization randomly changes once it is refracted back to the surface.
Hope this helps.
Rob 2E1IIP
