AM (Not the morning-y one) on HF.
- Call Sign: 26DG01
Is there a place on HF (aside from 5MHz...) where AM is actually used? I'd like to give it a go, I know it can be used on most bands. It would make sense to go somewhere where there is some activity, ideally in the evenings/nights. I've been listening on 10/11m but heard nothing as it's usually quite late.
Sent from my GP300 using DTMF
- Call Sign: Lemmy
Re: AM (Not the morning-y one) on HF.
Not popular in EU, but I heard a lot of NA stations in AM. Not possible to work them, because thay transmit over 3.8MHz
- Tigersaw
- Call Sign: GW6RRL
I gave it a go on 80m once. Upset loads of people who like having something to get upset about.
- DX-Digger
- Call Sign: TM205
Sunday Morning AM Nets mainly on Top Band 1.940MHz 10 am.
Albert G4DHO and a few others have a chat all welcome
- Adriano9966
When it is open on ten metres there is an AM sub band still in use both in the USA and across Europe
Usually this is in between 29.000-29.100 Mhz with a ten Khz spacing .
There is a curious mixture of equipment in use from converted AM CB transceivers (10 khz spacing fairly obvious that one) former broadcast equipment and home brewed AM transceivers .
I have had some fabulous QSOs up there on AM using very low power . 500mw and even 200mw .
There is a definite hard core of amateurs on the Eastern seaboard of the USA that use AM on 29Mhz
- Call Sign: 26DG01
Thanks, I'll give 1940 a try if I can tune it. I like 10m too, I can keep an eye on that /m.
