2m/70cm Antenna in loft...worth sticking it outside?
cmat100
Post by cmat100 » 25 May 2018, 23:03
Hi,
Currently have an X-30 as high up in the loft as I can get it (unless I drill a hole in the roof, might cause a few problems :) ). I can put it on the gable-end outside which would gain 3ft of height with the same length of WF-103 but wondering if it's worth it? It's a 1970s standard house with the usual tiles etc. No foil etc.
Sticking it outside requires diplomacy with "she who doesn't like wires and stuff". Hence the X-30.
Just wondering if someone has moved the same-ish antenna from the loft to outside and noticed a practical difference. I spent ages googling roof tile attenuation etc but there's no definite answer unless it's 2.4GHz, other than "wet doesn't help". True.
TIA,
Mat.
Tigersaw
Call Sign: GW6RRL
Re: 2m/70cm Antenna in loft...worth sticking it outside?
Post by Tigersaw » 25 May 2018, 23:22
I had an X30 that worked much better in the loft suspended just above the water tank than it did outside at a similar height.
Transwarp
Call Sign: Viper
Post by Transwarp » 26 May 2018, 09:46
You're always going to get better performance with an outside antenna, if you can put it outside and as high as possible then you should.
Farty
Post by Farty » 26 May 2018, 17:16
Try it and see. I used to get the South coast on simplex 10 watts a hundred miles away with my loft mounted job, worked very well.
cmat100
Post by cmat100 » 26 May 2018, 21:47
Wish I knew that before I had the water tank taken out a few years ago :) No way of doing it temporarily though - ladder, concrete screws and pole needed.
Cheers for the replies, might flip a coin - or duct tape it to the eaves - she'll love than hehehe :)
Buick Mackane
Post by Buick Mackane » 26 May 2018, 22:12
Outside and as high as possible.
LeakyFeeder
Post by LeakyFeeder » 28 May 2018, 20:10
Put ya foot down with a firm hand and get it shoved up high (the antenna that is)...man or mouse ;)
cmat100
Post by cmat100 » 28 May 2018, 20:37
Would put the foot down and get it right up there, but her parents house got hit by lightning, burnt the roof out, blew the TV up and knocked out Virgin for the whole street. House was uninhabitable for a few months.......
Hence the 'diplomacy' ;)
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Post by MrWeetabix » 28 May 2018, 22:21
Its an Act of God...... he obviously too exception to something that Virgin aired on their channels!
Get it on, get it out and get it HIGH!
Print that on a T-Shirt while you're on too! haha
