Alinco DR-605E how to enter PMR446 channels
WARLOCK
Call Sign: 26TM134
Post by WARLOCK » 11 May 2018, 10:36
Can anyone please HELP just bought a alinco dr-605e expanded 2/70 radio which i would like to use for PMR 446 use anyone have ant thoughts as to how to do this ,If anyone can help thanks ..
Call Sign: n0call
Re: Alinco DR-605E how to enter PMR446 channels
Post by ch25 » 11 May 2018, 11:04
You can't. No 6.25 tuning step in that rig.
WARLOCK
Call Sign: 26TM134
Post by WARLOCK » 11 May 2018, 13:13
Thanks Chris, Back to the drawing board have to look out for another radio ???
from George
Call Sign: G4RMT
Post by paulears » 11 May 2018, 13:23
What were you going to do if you had those frequencies available? If you were going to talk to people with proper PMR446 radios, then the deviation, the frequency and CTCSS would have to be set correctly - and you'd still be working illegally, but if you were going to talk to friends over greater distances, then you could go a bit higher or lower and do it, still, of course just as illegally. If you're willing to break the law, that's up to you - but unless you want to speak to people you don't know ..........
Call Sign: n0call
Post by ch25 » 11 May 2018, 13:55
Buy PMR radio George. That band is not for transmitting high power from base antennas. Doing that you will be jamming others you don't even hear in a very long range.
Farty
Post by Farty » 11 May 2018, 19:07
Go nuts on 446 George. Every other bugger does.
