ameture satilites
gerald123
ameture satilites
Post by gerald123 » 03 Apr 2018, 23:58
hi can someone tell me what are the eseast ameture satelites to track and monitor... and the frequencies to monitor them..i have downloaded [ orbitron tracker]
Auldgeek
Re: ameture satilites
Post by Auldgeek » 04 Apr 2018, 00:52
The best source of information is available from Amsatuk.
https://amsat-uk.org
However, here's a link to a German website that has a list of the current Amateur satellites with their corresponding transponder frequencies.
http://www.dk3wn.info/p/?page_id=29535
For listening purposes, you only need to look at the downlink side.
Generally, satellites with HF or VHF downlinks are the easiest to hear as you do not need sophisticated equipment and aerials. The funcubes are easy to hear, as is Oscar 7 (A-O7)
A quadrifilar helix (QFH) for 2m is an ideal aerial for general satellite reception. Easily built with some pvc tubing, copper tubing and coax cable. Another option is a turnstile. Plenty info on the web about both. Google is your friend. :thumbup:
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
gerald123
Post by gerald123 » 04 Apr 2018, 10:19
thank you for the fast reply kilimax.. some great info there..will keep me busy for a while..
Auldgeek
Post by Auldgeek » 04 Apr 2018, 11:55
gerald123 wrote:
04 Apr 2018, 10:19
You're welcome :thumbup:
For info, here's a photograph of my Quadrifilar Helix. This one is sized to work best at 137Mhz, specifically to receive the NOAA westher sats. It does work on 2m though.
gerald123
Post by gerald123 » 05 Apr 2018, 10:57
thanks again for the photoe ...i am going to have a go at making theQuadrifilar Helix antenna...can you tell me the best software to track the sats .... is there something better than orbitron..
Auldgeek
Post by Auldgeek » 05 Apr 2018, 13:05
gerald123 wrote:
05 Apr 2018, 10:57
I use software called wxtrack. Nothing better in my opinion.
Designed to track weather sats but does the job for amateur sats too.
http://www.satsignal.eu/software/wxtrack.htm
gerald123
Post by gerald123 » 05 Apr 2018, 23:44
i have opned the zip file and extracted ... for wxtrack but canot get software to run.....help
bozzy
Post by bozzy » 06 Apr 2018, 16:30
Just to expand on a link that was posted.
http://amsat.org.ar/pass.htm#
Once you get used to the graphics and set your location (and zoom in a bit), it is very useful to see what is currently above you.
Also best using chrome browser with it.
Auldgeek
Post by Auldgeek » 06 Apr 2018, 20:45
gerald123 wrote:
05 Apr 2018, 23:44
You will need some additional runtime files (dll's) before launching the software. Scroll further down the page on the wxtrack site and there's additional information on what you need.
gerald123
Post by gerald123 » 07 Apr 2018, 10:34
bozzy wrote:
06 Apr 2018, 16:30
thanks for the link ...verry good
Auldgeek
Post by Auldgeek » 07 Apr 2018, 11:01
bozzy wrote:
06 Apr 2018, 16:30
That's just far too busy and extremely poor graphical coding. It's informative but I just couldn't use that on a regualr basis.
Samalex
Call Sign: MM0
Post by Samalex » 08 Apr 2018, 18:26
SATPC32
tracks and can control radio if needed.
i just started playing a few months ago and used a log till i put a 9 ele for 2m and 23 for 70cm
going to change them to cross yagis soon or X-Quads
fm sats easy as most have fm radio so SO-50 AO-85 AO-91 AO-92 Freqs you probably have now
have fun :)
Auldgeek
Post by Auldgeek » 08 Apr 2018, 18:48
Samalex wrote:
08 Apr 2018, 18:26
SATPC32
have fun :)
I can recommend the Wimo X-Quads. Very good performance and rear mounting for maximum performance and much easier to elevate than conventional X-Yagis.
Samalex
Call Sign: MM0
Post by Samalex » 09 Apr 2018, 10:36
thanks Drew for the recommendation
gerald123
Post by gerald123 » 09 Apr 2018, 23:08
thanks you all for the feed back verry much apresiated .
