Diy Hf vertical
nordhavn
Diy Hf vertical
Post by nordhavn » 02 Jan 2018, 17:39
I'd like to have a go at making an hf vertical . From my understanding a simple one would be to use a 1/2 wave Silver rod with the loading coil removed and a 9:1 balun at the base . Would a better quality antenna such as a sirio 827 make much of a difference ?
Regards
Call Sign: n0call
Re: Diy Hf vertical
Post by ch25 » 02 Jan 2018, 17:55
nordhavn wrote:
02 Jan 2018, 17:39
What bands it suppouse to work?
nordhavn wrote:
02 Jan 2018, 17:39
No. You have no idea about feedpoint impedance, so no one knows what (if) balun you need.
nordhavn wrote:
02 Jan 2018, 17:39
No.
Btw do not forget radials. At least 2 1/4 wave for each band.
Maybe that is an antenna you think about? http://www.g8jnj.net/cometcha250b.htm
That is something worth building: http://www.tc2m.info/
stanogs68
Re: Diy Hf vertical
Post by stanogs68 » 02 Jan 2018, 18:29
ch25 wrote:
02 Jan 2018, 17:55
nordhavn wrote:
02 Jan 2018, 17:39
nordhavn wrote:
02 Jan 2018, 17:39
nordhavn wrote:
02 Jan 2018, 17:39
No.
wko transmits on hf broadband ?
Users browsing this forum: Majestic-12 [Bot] and 2 guests
