I've got a redundant telegraph pole at the end of my property which would be ideal to run a long wire to . It's exactly 20 meters from my conservatory/radio room .
What/how would be the the easiest way to get a wire up there ?
advice needed
- Banned
Re: advice needed
Climb it if you are fit enough and install a pulley wheel or use use a ladder while you have 2 people supporting it. Attach a cord through wheel so it's ready to hoist up later meaning you will not have to go back up.
Broad sword calling Danny boy......
Re: advice needed
I can't advise you how to get the job done, but I can advise that if you or someone is going up then use a ladder to the top and don't use the footplates that start half way up, those poles get certified every 5 years (I think) and if the stamp at the bottom isn't in date then a BT guy or girl won't go up, they will request a cherry picker. If that one is abandoned then it's safety cert probably expired decades ago.
- Call Sign: oh5nxo
Re: advice needed
There are not any kind of hooks left at the top ? Fishing line & weight, slingshot, kite etc ... Never done it, but using a kite to position a noose around the tip, then tightening might not be impossible.
Juha
Juha
- Call Sign: G4RMT
Re: advice needed
Ladder and lashing. Usual precautions but I'd certainly go with the suggestion to install a pulley at the top. Makes life simple later.
- Auldgeek
- Call Sign: GM0BRJ
Re: advice needed
I had a similar telegraph pole at a previous property a few years back but I went a bit further and fitted a small (1.5m) extension aluminium pole secured by drilling through it and fitting a couple of small brackets. I then attached a pulley to it. My main reason for doing this was to install a Quadrifilar Helical antenna to the top for wx satellite reception but got a secondary use as a mount for wire antennas.
Usual H&S rules apply though. Ladders can be extremely difficult to use because of the circular shape of the pole so be careful. Do not climb it on your own!
Auldgeek - Drew
- nordhavn
Re: advice needed
Thanks , a pulley system would work well as I don't fancy going up there often.
- stanogs68
Re: advice needed
http://www.ebay.com/bhp/tree-climbing-spikes you could allways try these
love your familly
