Numbers station on top band NOW
- nay27uk
M6LIG / 2E0LIG / 26TM1995
Baofeng UV5R+
Boafeng RD-5R
YAESU FT-857D - Watson W50 - HF-SE-360
Malahit SDR - Ground Loop
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
- nay27uk
Re: Numbers station on top band NOW
Man some weird stuff on top band this morning, Now on 1988.96 is this thing.
Both the above recorded of the Hack Green online SDR
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
- Call Sign: G4RMT
I love the numbers stations, and still find the idea of somebody, somewhere, writing down the numbers, using their one-time pad, and receiving secret messages from their bosses. In this day and age of decoding comms that we talk about so often, the notion of an old, unbreakable system makes me smile - and worse, makes me remember that people out there are still doing the really secret stuff.
- nay27uk
Ha ha yeah paulers I don't think the antennas to receive it would be very secret though at those frequencies even a stealth long wire would be noticeable, you certainly wouldn't be fitting it in a hotel room.
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
- Tigersaw
- Call Sign: GW6RRL
thats a met report
- mercury888
- Call Sign: M0RVB
Numbers stations started my shortwave interest when I was a kid. I remember listening to what I had assumed to be a German woman sitting at a mic reading numbers over and over.
Mind you, I also remember running off yards of paper from a Creed 7E teleprinter decades ago, all numbers in columns assuming they were code, only later to find it was weather data.
CB: President Grant II (1980's handle: Bootstrap; now 26TM868)
ADS-B: FR24 T-EGNM-63
Yaseu FT450D; Signal R535; W-SDRX1 + Gnu Radio and CubicSDR
Baofeng UV5R; TYT MD380; Trio TR-9130
- Call Sign: oh5nxo
Could it be, that the hardware there does not handle strong signals? I only know about RTL DVB stick, the common one, it invents a lot of stations. Airport, nearest FM station and the closest ham (100yards) are here and there on the dial. Were, actually, moved to countryside now.nay27uk wrote:the Hack Green online SDR
Juha
- nay27uk
No I think the Hack Green kit is quite top notch stuffoh5nxo wrote:Could it be, that the hardware there does not handle strong signals? I only know about RTL DVB stick, the common one, it invents a lot of stations. Airport, nearest FM station and the closest ham (100yards) are here and there on the dial. Were, actually, moved to countryside now.nay27uk wrote:the Hack Green online SDR
Juha
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
There's a page of info about the Hack Green receiver setup here - not quite an RTL DVB stick
- nay27uk
Yep seen that before it uses the same chip as the Softrock Ensemble 11 I built a few years ago and had to reluctantly sell due to needing the money. it uses the SI chipset so bang on frequency and the filters are top notch on thew ensemble 11.Freddie wrote:There's a page of info about the Hack Green receiver setup here - not quite an RTL DVB stick
very similar to the hack green kit
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
- nay27uk
Yep seen that before it uses the same chip as the Softrock Ensemble 11 I built a few years ago and had to reluctantly sell due to needing the money. it uses the SI chipset so bang on frequency and the filters are top notch on thew ensemble 11.nay27uk wrote:Freddie wrote:There's a page of info about the Hack Green receiver setup here - not quite an RTL DVB stick
very similar to the hack green kit.
I must purchase another Ensemble 2 or 3 kit and get it built.
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
- nay27uk
nay27uk wrote:Yep seen that before, it uses the same chip as the Softrock Ensemble 11 KIT that I purchased and built a few years ago and had to reluctantly sell due to needing the money. it uses the SI chipset so bang on frequency and the filters are top notch on thew ensemble 11.nay27uk wrote:Freddie wrote:There's a page of info about the Hack Green receiver setup here - not quite an RTL DVB stick
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
- nay27uk
Yep seen that before, it uses the same chip as the Softrock Ensemble 11 KIT that I purchased and built a few years ago and had to reluctantly sell due to needing the money. it uses the SI chipset so bang on frequency and the filters are top notch on thew ensemble 11.nay27uk wrote:nay27uk wrote:nay27uk wrote:
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
- nay27uk
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
- nay27uk
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
