40m Loft Antenna
Buick Mackane
40m Loft Antenna
Post by Buick Mackane » 29 Jan 2017, 19:53
Right. I wanna get myself onto HF, The band that interests me is 40m. Now what can i squeeze in the loft that will cover that band ? The length of the loft is roughly 18ft. So a dipole is really out the question unless i zigzag it all over the joint. I was thinking about buying a 40m mobile whip and bunging that up, But before i go spending my hard earned is there anything i can knock up myself to do the job.
Cheers gents.
Call Sign: n0call
Re: 40m Loft Antenna
Post by ch25 » 29 Jan 2017, 20:04
You really want to radiate rf right into your body? lol
mercury888
Call Sign: M6IGP
Post by mercury888 » 29 Jan 2017, 21:02
Allegedly one can run a random wire thru a 9:1 un-un to match to 50 ohms provided the wire length is not resonant on the band you want. I'm about to have a go at one of these. My radios are on the first floor so I'm to gonna manage a decent earth.
The issue is you need a decent length of coax to act as 'earth' (so they say) and can't use a coax choke, so quite how well it will work I dunno.
I have (well, will have) a fan dipole in the loft so far (only 6m right now but adding more) which the FT450D is happy with but it's as noisy as one would expect with all the other stuff up there.
CB: President Grant II (1980's handle: Bootstrap; now 26TM868)
ADS-B: FR24 T-EGNM-63
Yaseu FT450D; Signal R535; W-SDRX1 + Gnu Radio and CubicSDR
Baofeng UV5R; TYT MD380; Trio TR-9130
NightProwler
Call Sign: 163TM186
Post by NightProwler » 29 Jan 2017, 21:19
I had a dipole for 40M running around my attic and it was terrible. Get it outside.
Tigersaw
Call Sign: GW6RRL
Post by Tigersaw » 29 Jan 2017, 21:50
If you are using a un-un it will have a hot and cold side. Hot side to your antenna wire and cold side as counterpoise.
experiment.. I gave one a go, hot side to the ex TV antenna (so a vertical piece of wire running up the chimney to a small top hat) and the cold side to the water tank feed.
It would match most bands 80-10, worked best on 80m and I had a few rag chews 100 miles radius
edit: most other antenna ideas I tried in the loft were pants. Had a bit of luck with a 6m bazooka dipole when the band was open, but thats about it.
Auldgeek
Post by Auldgeek » 30 Jan 2017, 14:27
There's a number of topics on the web that suggest different options for indoor or "stealth antennas" if you are stuck for space. Outside is always better but good results are possible with indoor antennas. If you have 18' (square?) to play with, there's room for a folded dipole and if you add a pair of traps, you would extend the number of useful bands. Another tried and tested design is a delta loop and again, you can fit that into the space you have. Just Google indoor 40m antennas.
Performance will be down on an outside antenna and noise could be an issue but you won't know until you try.
Edit**
Link to a useful website for antennas
http://www.dxzone.com/catalog/Antennas/ ... _Antennas/
Auldgeek - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
madman1027
Post by madman1027 » 30 Jan 2017, 19:00
i went for a 40m loop just folded & bent to fit in the loft, it wasn't perfect but worked alright.
Buick Mackane
Post by Buick Mackane » 30 Jan 2017, 19:02
Thanks for the suggestions. Much appreciated. But i was hoping there might have been a quick fix, Something i could just chuck up and forget about, Don't have a lot of time at the min for antenna experimenting, But the info posted will come in handy at a later date when i have more time to muck about with antennas, The folding dipole looks interesting,
cheers
dxgtlswr
Call Sign: 108TM711
Post by dxgtlswr » 01 Feb 2017, 10:14
Buick Mackane wrote:Right. I wanna get myself onto HF, The band that interests me is 40m. Now what can i squeeze in the loft that will cover that band ? The length of the loft is roughly 18ft. So a dipole is really out the question unless i zigzag it all over the joint. I was thinking about buying a 40m mobile whip and bunging that up, But before i go spending my hard earned is there anything i can knock up myself to do the job.Cheers gents.
Hello Buick!...I'm currently using A HF mini (monoband) dipole, Which just fits in my 15ft wide - balcony.
Working stateside/Canada with 10 watts no bother at all.
See the link below.
http://www.sandpiperaerials.com/product ... i-dipoles/
All the best.
http://www.mm6kha.uk
Cheers gents.[/quote]
Buick Mackane
Post by Buick Mackane » 01 Feb 2017, 10:55
Ideal dxg but a tad pricey. But definitely worth considering. Cheers.
jkb
Post by jkb » 01 Feb 2017, 16:16
What about a long wire hidden behind your gutter?
Buick Mackane
Post by Buick Mackane » 01 Feb 2017, 16:33
jkb wrote:What about a long wire hidden behind your gutter?
iv'e purchased a 40m mobile whip, it'll probably be crap, but time will tell, kinda tempted by the short dipoles the guy above posted a link too. just wish i'd seen them before buying the whip. {bnghd}
dxgtlswr
Call Sign: 108TM711
Post by dxgtlswr » 01 Feb 2017, 20:43
Buick Mackane wrote:Ideal dxg but a tad pricey. But definitely worth considering. Cheers.
Hello Buick!....Cheaper @ - http://www.radioworld.co.uk/hf-mini-dip ... r%20dipole
Karl,
73.
Buick Mackane
Post by Buick Mackane » 01 Feb 2017, 20:49
Karl,
73.
Roughly the same when you include postage, But thanks pal, Think i'll buy one.
EDIT my mistake radioworld is about a fiver cheaper :thumbup:
