Hi all , i may be being thick here but i need to control my transverter from my old but faithful icom 730...
ive looked at the acccessory socket and trying to find a pin that goes to ground on tx...
no luck is there another way doing it.. the transeverter has a simple phono socket on back when grounded goes into tx mode..
cheers in advance
paul
g4sbx
icom 730 help with PTT for transverter
- Call Sign: g4sbx
- Admiral
- Call Sign: 26TM157
Re: icom 730 help with PTT for transverter
Is it not pin3 and 11 on the accessory block for transverter use??????????
- Call Sign: g4sbx
Hi tnx for quick reply...pin 11 has 8volts on it which prob could be connected via relay....pin 3 goes 12v olts when mike keyed..im confused as manual does indicate pin 11 but im not sure how to wire it...
paul
paul
- Admiral
If you're just looking for a switched ground via the PTT can't you go route1 and do a continuity test putting one side to ground and then probing for a match when keying?
- Call Sign: g4sbx
hi admiral
i will look again and try ur suggestion although none are mentioned on icom handbook...
tnx agn
paul
tnx agn
paul
