anyone recommend a good UK supplier?
im looking to order some QSL cards, never done this before
thanks for your help
73s
creating QSL cards
- MW0SWA
- Call Sign: MW0SWA
creating QSL cards
I am a bit crazy about the Realistic DX-394
Re: creating QSL cards
I do my own on the PC, but Des Currie in Consett near Durham is hard to beat.
Really good guy and does a great job.
If you don't mind using someone outside the UK, then UX5UO prints excellent quality cards at reasonable prices.
http://www.ux5uoqsl.com/index.php?lang=en&page=products
Payment can be made to his UK representative M0OXO.
- ClubbaUK
You could always E-QSL and save a load of dosh and waiting time by doing so.
http://www.eqsl.cc
UK international postage is too expensive IMO and if you make 100 contacts a month you'll soon see how expensive posted QSLs can be.
http://www.eqsl.cc
I can recommend Geoff G8RCZ as the service is second to none and delivery time very quick.
http://fdsqsl.com/
Cost me £13 inc delivery for 100 high quality cards - with a custom design - see images below.
http://fdsqsl.com/
- Adriano9966
2SG wrote:If you don't mind using someone outside the UK, then UX5UO prints excellent quality cards at reasonable prices.
This is not an answer to your question, but I too print my own as I use about 1 a month. I use a 7x5 or 127 x 178 mm 200 gsm photo paper, print the postcard bit on the matt backside and the image on the front, think they're about 7 or 8 quid for 50 from Staples and other good office outlets. It may work out dearer than having them printed by a professional, but you can chop and change them as you wish to personalise differently.
If it's home designed and printed you are after, then this is a neat little programme to play around with.
http://qsldesignandprint.software.informer.com/
- Call Sign: 20TM896
As a minimum you should include the Maidenhead locator (a.k.a. "grid"), CQ and ITU zone to put your station on the map.
Also strongly consider to include information for common amateur radio awards in your country, f.i.: WAB square, county, district and/or similar.
People still collect physical diplomas out there.
This part adds more fun to the hobby, but if all people stop giving additional information at their QSL (as many already did) your counterpart does not have proof to claim a score for the contact.
Check this list to find relevant awards and their requirements for most countries
http://www.qsl.net/va3rj/awards_dx.html
If you are operating often as mobile or portable station - consider having a separate card for such operations, where values above can be filled in.
Make sure to add fields for awards related to operations from temporary QTHs, the most common are SOTA, WWFF and IOTA.
A bit off topic, but highly relevant to the last line above: Want to be a (radio) star for some hours:
Try climbing a SOTA top or enter a WWFF area and operate from there at a common HF band. You will most probably end up being the middle of a pile up within minutes!
And please: Anyone who read this and like awards; please spread the word to your fellow operators.
More people should give more info than the minimum requirements - regardless the type of QSL you send.
TRX:
Icom 7300 / 706 mk II / 735 - Alinco DR-135DX - President Grant mk II / Jackson mk I - CRT SS9900 / One - Anytone AT300M
Icom ID 51E - QYT KT-8900 - Icom F4SR / 28H - Baofeng UV-5R / 888S
