Hi guys, I've developed a slight hum on my transmission as of this morning. It's on 2m analogue only. It doesn't appear on 70cm or 2m DSTAR which is weird.
I'm running an Icom 5100 with a PS30SW2 power supply. The buzz appears on 5w, and I did a quick blank key to test on 15w and above and it's still apparent.
As far as I can see there's nothing in the house that has changed that could be causing the buzz but it's a strange one.
Any ideas?
Slight Hum Query
Slight Hum Query
CHECK OUT MY RADIO BLOG
http://distantsignalradio.blogspot.co.uk/
My Youtube
https://www.youtube.com/channel/UC67TJP ... i2h1aaSO6Q
My Youtube
- Call Sign: MM0
Re: Slight Hum Query
2m antenna swr ? check the power supply volatge and the way you have cables connected and laid out.
make sure all conections are removed except antenna mic and power and try if still there check SWR. check the way the power cables go to the radio like wise with coax. if all clear add the cables one by one in to the radio see if it comes back
- Andy
Is the hum actually on your transmission? Most hums that you can hear from your own sigs are local effects caused by the RF intermodding on the mains 50/100 Hz and aren'y 'really' there. If I monitor my 160m transmissions on a portable radio, there is a strong 100Hz buzz present, but no-one else can hear any trace of it.
'SOMEONE GET ME A SAW!'
Andy.
Andy.
Cheers, I'll check that out
My Youtube
My Youtube
