Small garden Antenna for HF bands
- Call Sign: mi3txi
SE HF-360 Vertical
What is the screw at the bottom of the aerial for, at the bottom of the bottom pole. thanks.
- gmham
- Call Sign: 108TM154
Re: Small garden Antenna for HF bands
From the picture online and if it's the screw that I think you are talking about I would think it's just part off the design.. a securing screw.
https://www.ebay.co.uk/i/261951437629?c ... 1831348066
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- GaryWilson
- Call Sign: 2E0GGQ
This is what I use https://www.gwhip.co.uk/421-triband-antenna it does 40 20 & 10 without a tuner and is only about 36 foot long so will work in a pretty small garden, mine is sloping from the eaves and is tied off to a tree, works very well indeed.
73s Gary.
73s Gary.
26CT1836 2E0GGQ
"Very well" means vk9ci, vk9xi, vk9cz, a25a etc. in the log, right?
- GaryWilson
- Call Sign: 2E0GGQ
What ever you say Chris, if you have limited space this is a pretty good option, I never suggested it could match the likes of a Yagi and with HF conditions so poor at the moment the chances of VK ect are pretty slim. The opp has a 10 watt limit so with current conditions VK would be a bit of a stretch. It was just my suggestion I look forward to seeing yours which seems to be missing from your sarcastic but all too familiar reply.
73 Gary.
26CT1836 2E0GGQ
- nay27uk
MyAntennas EFHW 1080 http://myantennas.com/wp/product/efhw-8010/ is supposed to be the bee's knees in endfedz and can be mounted in just about any configuration you can think of from inverted V, L to zigzag with no performance losses.
If you're in the UK though I would just copy it homebrew for a lot less dosh due to it being american based by the time you paid import duty it would have cost you over £200. Plenty of videos on them and info around to make one.
Some reviews of the MyAntennas EFHW 8010 HERE
M6LIG / 2E0LIG / 26TM1995
Baofeng UV5R+
Boafeng RD-5R
Malahit SDR - Ground Loop
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
- Call Sign: 26CT2116
44 foot doublet - in an inverted v with about the last 6 feet drooping down - fits into 30 foot of space in my garden. Fed with 300ohm twin lead into an ATU - tunes 40-10 and even 80!
Got a video of its construction and use too if anyone is interested lol.
