Small QRP ATU with built in meter.
bc73
Post by bc73 » 22 Jan 2019, 21:49
Hi All,
Could anyone recommend a small QRP ATU that has a meter on, been looking around but found nowt.
Any suggestions would be gratefully received.
MM6BCF
108 TM 45
FT-747-GX.
IC-706-MK2G
Yaesu FT7
Stalker 9FDX
Dirland SS3900E
Nato 2000
Alinco DR135
Amstrad 901
73 and 51
Nothing's ever easy! {bnghd}
kilimax
Call Sign: GM0BRJ
Re: Small QRP ATU with built in meter.
Post by kilimax » 22 Jan 2019, 23:04
The only small ATUs that I know of with a meter are from MFJ. They manufacturer the MFJ-945e and an older 971 but they are not QRP, being rated at 200-300 watts (that's MFJ watts)
They are compact and have built in metering.
Both are advertised as mobile tuners.
Kilimax - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
bc73
Post by bc73 » 25 Jan 2019, 20:07
Cheers Drew ,
I saw both of those but as you say not very compact or Qrp. Looking for a tuner to use with my Yaesu FT 7 .
Thanks Col
MM6BCF
108 TM 45
FT-747-GX.
IC-706-MK2G
Yaesu FT7
Stalker 9FDX
Dirland SS3900E
Nato 2000
Alinco DR135
Amstrad 901
73 and 51
DX-Digger
Call Sign: TM205
Post by DX-Digger » 25 Jan 2019, 21:58
You could build one?
Not my design but links shown in text :D
kilimax
Call Sign: GM0BRJ
Post by kilimax » 26 Jan 2019, 08:43
bc73 wrote:
25 Jan 2019, 20:07
Due to your requirements for a built in meter, you are going to struggle to find anything.
The 945e is actually quite compact, measuring just 8" across, 6" from front to back and 2" in height. Bear in mind, you have 2 airspace variable capacitors, a switchable inductor and a meter plus some circuitry inside. All depends on your installation, as you never mentioned if you plan to use it fixed station or mobile? The FT-7 isn't exactly compact by modern standards, so the 945e should fit the bill but all depends on your operating conditions.
One weak point is the meter is quite small but it would be very difficult to cram anything bigger in that case.
Anyway, good luck with your search Col.
Kilimax - Drew
M0JSW
Post by M0JSW » 07 Feb 2019, 16:47
If you do decide to go down the road of making one, I can recommend the 'AMU mk6' by Walford electronics.
http://www.walfords.net/accessories.htm
I bought one to go with my uBITX and was really surprised how good it is. It's good for 20w, tunes 3.5 - 30mhz and will do 160m depending on the antenna. The switchable vswr bridge has an LED indicator (the dimmer the light... The better the vswr) and it only took an evening to put together. You do need to be able to wind toroids ... It has 8!
M0JSW
