CBS-441.775Mhz
ANCIENTMARINER
CBS-441.775Mhz
Post by ANCIENTMARINER » 13 Oct 2015, 14:14
Greetings,
This CBS repeater at Braithwell near Doncaster very active today. Tones logged:
141.3 218.1 88.5
Anyone identify these users ?
I have 218.1 as taxi firm in Donny, 88.5 as a skip firm Donny/retford areas, and 141.3 a new one unidentified business.
Any help much appreciated.
Rgds,
Alan
dalehull83
New User
New User
Re: CBS-441.775Mhz
Post by dalehull83 » 13 Oct 2015, 15:48
Hello,
the only one I can help you with is 218.1 is little arrow taxis, based at the terminal building robin hood airport
Dale
phillmobile
Re: CBS-441.775Mhz
Post by phillmobile » 13 Oct 2015, 22:48
also try 441.175 and 441.875 i think or something like that
ANCIENTMARINER
Re: CBS-441.775Mhz
Post by ANCIENTMARINER » 14 Oct 2015, 20:56
Thanks for that Phil. I knew about Little Arrow as they changed their tone code a bit back.I also noticed 165.3 is active again .Seems like some of the previous users coming back slowly to CBS which is good.BTW i managed to sort out the 165.7375 user that had two tones with the talkthrough open.This was a taxi firm in Wakefield. Why they use that channel like that i dont know. Also dando looks like he is using TRBO on that same frequency.
Alan
LeakyFeeder
Re: CBS-441.775Mhz
Post by LeakyFeeder » 15 Oct 2015, 12:35
Are these paired with inputs on the 427mhz range?
ANCIENTMARINER
Re: CBS-441.775Mhz
Post by ANCIENTMARINER » 18 Oct 2015, 20:15
Hi Leakythingbob,
Yes with 427.275 for 441.775
A
LeakyFeeder
Re: CBS-441.775Mhz
Post by LeakyFeeder » 18 Oct 2015, 21:49
Cheers for that.. Will listen on the input aswell when im round the area...
Im sure that site is where GB3DV used to be sited some years ago
phillmobile
Re: CBS-441.775Mhz
Post by phillmobile » 27 Feb 2016, 00:56
441.8250 192.8 is Yorkshire Aggs i think
