433.025 heard in Boston, Lincs
albrecht
Post by albrecht » 21 Aug 2015, 08:27
I heard Americans speaking on a network on this repeater, also a chap in Leicester UK. How does one get access to this repeater to speak to the States(?), some of them were using Baofeng UV5RVs. Thanks.
Lumiya
Re: 433.025 heard in Boston, Lincs
Post by Lumiya » 21 Aug 2015, 09:41
Probably DV in Maltby running echolink/irlp
CB since '85
AR since '91
Ex-RAF
If you get just a YES or NO answer it will mean either you should already know the answer or you have proved yourself incapable of understanding the answer. Also if you think I need to explain what I type then perhaps you should realise your own limitations
astrolab
Call Sign: F0GIQ
Post by astrolab » 26 Aug 2015, 03:43
All is here : http://www.echolink.org/
Regards
Michel
CB's collector-IC 706 MK II-FTM 350 R/E Ant X300-FD3-Black Pirate....
