Came across this Voice Channel today while preforming a quick search of the UHF Bands... Checked the WTR with no luck, and searched the interweb.
Its Simplex, not Repeater based.
The only tie up to this frequency ive seen so far is that its registered as one of the 'London 2012 Olympic Delivery Authority' frequencies. What exactly that means im not sure so hoping that someone can shed some light, cheers...
456.8875 MHz - ????
- lincs_radio
456.8875 MHz - ????
LincsRX
- wind in the antenna
Re: 456.8875 MHz - ????
That's an interesting one. It used to be used by Siemens VDO under a Business Radio (Public Mobile Data, Non-Voice) licence, and was then at one time shown licenced to the ODA. Both licences were duplex.
New Face in Hell
Tony in Brighton
26TM9480
26FB298
G7TXU
- lincs_radio
I'll continue to monitor...
I could be wrong of course, but it sure sounded simplex due to the different signal strengths and noise level between each side of the conversation. Unless of course i was listening to the Input, making the Duplex 462.3875 i believe... will monitor both.
Another quick search comes up with:
456.8875 462.3875 U1351 OFCOM CHANNEL NUMBER UHF BANDS FM Feb-06
456.8875 462.3875 SHORT TERM PBR EVENT/RESERVED CHANNELS ARE USED SINGLE OR DUAL BASE OR MOBILE LEG OFCOM EVENT PBR MAIN FM Jul-06
456.8875 462.3875 SIEMENS VDO NATIONAL MOBILE DATA TERMINAL MULTI USER MDT FM Oct-05
456.8875 DCS 627 UNID LONDON W1 LONDON FM MAY-07
LincsRX
