Mototrbo? Shrewsbury
Scanning radio frequencies in the West Midlands
Andyman
Call Sign: 163CT037
Post by Andyman » 10 Feb 2013, 21:02
I was searching around and I discovered in the WTR an entry for
"Storenet Security Systems Limited"
TX: 456.8375 MHz
RX: 462.3375 MHz
Bandwidth: 12.5 kHz
So I had a listen and is sounds like what I believe to be Mototrbo. I was just wondering if anyone had had a go a decoding it to find out what its about. It is active late on a Sunday night so I am wondering if it is a shopwatch? Either that or it is the royal hospital security perhaps, as I live close to the hospital?
Thanks in advance!
thelad
Re: Mototrbo? Shrewsbury
Post by thelad » 10 Feb 2013, 22:17
Most likely "pubwatch" and "shopwatch" in the day time, the WTR should give you a map ref to where the radio freq is being used in most cases. It can be decoded use "DSD for windows" , google it.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
