Birmingham Airport Fire base on 455.575 NFM has such low audio modulation it is barely audible — you have to turn up the volume significantly compared to all other NFM transmissions.
It can't sound that quiet to them or the radios would be unusable.
The mobile transmissions on 461.225 don't show this problem, and nor does the Tower on 455.475, so what is going on?
It's always been like this — for at least 15 years.
Does this happen with other airport fire services?
Why do Birmingham Airport Fire have such quiet audio?
- Minus1
- jaybranch
Re: Why do Birmingham Airport Fire have such quiet audio?
I think I came across this before with a frequency in Newcastle... I switched it to 'FM' as oppose to 'NFM' and I could hear the audio much more!
The frequency was listed as 'NFM' though.
73 & 88
26TM1979
AOR3000A
Yupiterus (a lot!!)
VX-7R
Lowe HF 150 & 225
TS850 SAT
A longwire & GR5V
26TM1979
AOR3000A
Yupiterus (a lot!!)
VX-7R
Lowe HF 150 & 225
TS850 SAT
A longwire & GR5V
- nerdsville
Think it is probably do with different deviations, was a similar discussion about quiet transmissions a while back http://www.transmission1.co.uk/forum/vi ... =5&t=22163
- Minus1
Well, miracle of miracles, they must have had a radio upgrade, it now sounds perfectly normal.
- benw18
The fire control room has now moved onto a different part of the site... As have the antenna(s).
