2 new UHF freqs for kingsway centre - newport
Scanning radio frequencies in Wales
bigbloke
Post by bigbloke » 13 Dec 2015, 22:39
licence 1057353 on the WTR refers - first is DMR second seems not yet on air
currently unsure as to whether this is in addition to the G4S DMR system , or whether G4S lost the contract
regards
BB
bigbloke
Re: 2 new UHF freqs for kingsway centre - newport
Post by bigbloke » 14 Dec 2015, 13:38
hmm...plus ca change!
Seems that the G4S licenced callsigns "CHEETAH" have moved to the second of the new kingsway frequencies.
I suspect the old 447MHz frequency will therefore be dead now ?
they now share the higher frequency split by two DMR talkgroups / timeslots.
Facilities / management appear to be on one, cleaners appear to be on the other.
On the first frequency only one talkgroup seems in use, which appears to be security and is common to
both friars walk and the legacy kingsway arcade. This is in paralle with the main town storenet.
This brings Friars Walk's simplex licence into question, as to whether it too has been superseded - or whether it was a stop-gap?
There have been massive changes in Newport UHF allocations over the last 12 months - mainly it seems caused by the expansion of
TATA steel operations at Llanwern who have over doubled their number of active channels
more news as it unfolds
regards
BB
welshevo
Call Sign: 163TM995
Post by welshevo » 15 Dec 2015, 08:21
bigbloke whats the chances of being able to receive these in cardiff on a handie? or SDR with whitestick? are they running a CAP+?
regards
bigbloke
Post by bigbloke » 16 Dec 2015, 10:54
Hi,
No CAP+ nor RAS
But I suspect their "customer service" radios which I know are hyteras running on a simplex channel dont appear to decode suggesting they are
using the new standards "two slot simplex" which DSD / DSD+ (afaik) dont support yet.
As for whether you'd get these in Cardiff depends upon where in cardiff you are.
Take a look at the attached map:
Source: https://www.ordnancesurvey.co.uk/osmaps/
The red "ridge lines" lines I've overlaid roughly show how Newport city centre is isolated to the west and north by two hill ridges (brynglas
ridge omitted for clarity)
The horseshoe shaped ridge that runs from St Wollos , across Stelvio park to the Gaer, up to Glaslwch, the Ridgeway, across to
Alt-yr-yn and Barrack Hill where it is broken by the Usk valley,
On the east side of the river there is a second ridge that goes from Summerhill, across Beechwood and Christchurch and continues
up to the celtic manor.
In part these hills are why Newport city centre has retained much of its historic / victorian architecture as it was very tricky to bomb
the docks and still pull up in time during WWII
The TX sites in question are roughly in the centre of the horseshoe.
As such , if your somewhere like a coastal high spot near St mellons, theres a fair chance
If you're inland a bit, say , Roath or Llanishen, then your probably quite shielded unless you live up on the ridge between Llanedryn and Roath.
I'm fortunate as from my back garden, the next landfall to the west is the wenvoe ridge ! so I have the best of both worlds :-)
Regards
BB
welshevo
Call Sign: 163TM995
Post by welshevo » 16 Dec 2015, 12:36
Ahh bigbloke! im in both roath and llanishen so pretty sheilded!! unless i program them into my handie and drive around! hahaha im hoping when my white stick gets here i can pick up various from the loft! heres hoping!!!
bigbloke
Post by bigbloke » 16 Dec 2015, 21:27
good feeder is as,if not more important than a given white stick.
dont use rg-58 - get some good stuff :-)
Regards
BB
Christ85
Post by Christ85 » 02 Jul 2018, 13:13
I know the thread is pretty old now but for what it's worth..
It seems Kingsway are now using a "PTT over cell" system.
I wonder how quick the uptake will be of these systems? I imagine a few places will migrate sooner or later.
bigbloke
Post by bigbloke » 10 Aug 2018, 14:12
theyre using PoC for their management channel
security and cleaners remain on DMR
Regards
BB
