Cycle couriers Cardiff area
Scanning radio frequencies in Wales
Mikel
Post by Mikel » 07 Oct 2015, 07:16
Have been listening to these guys for a while. Monday to Friday between about 9.00 - 18.00 hrs.
165.700 MHz base
170.500 MHz mobile
Best to listen on the base/repeater frequency 165.700 MHz.
Can make interesting listening at times, with crashes, punctures, arguments etc. Should be able to be heard over a large area as the mast is located north of Cardiff, above Lisvane on the ridge between Cardiff and Caerphilly.
License details taken from the WTR are as follows:
Commercial Radio Systems Limited
Address
Unit 30
Bessemer Road
CARDIFF
CF11 8BA
Licence class
Business Radio (Technically Assigned)
Tradable licence
Y
Licence start date
16-05-2013
Frequencies and locations
Location(s)
ST 18900 85100
TX: 165.7 MHz
RX: 170.5 MHz
Bandwidth: 12.5 kHz
Colour Code: 14
TX: 166.1125 MHz
RX: 170.9125 MHz
Bandwidth: 12.5 kHz
Colour Code: 15
http://tinyurl.com/q5lz3ez
Heard nothing on the other licensed frequency yet and interesting that the license details give colour codes as all comms are analogue so far with the repeater operating with a ctcss of 179.9
The map below displays the location of the mast above Cardiff:
welshevo
Call Sign: 163TM995
Re: Cycle couriers Cardiff area
Post by welshevo » 07 Oct 2015, 14:55
interesting ... as i thought i seen one of these couriers using a motorola DP3400? which is a DMR radio? unless they are due to switch over and are still using the old VHF analogue stuff? ...but excellent find!! well done
Mikel
Post by Mikel » 07 Oct 2015, 17:38
They used to be heard on 165.0375/169.5375 for a long time but this was (still is?) a community repeater.
I seem to remember that a waste company was a heavy co user of the channel and communications for the courier company were difficult at times and the length of transmissions were restricted, you could hear 'time out tones' on longer transmissions.
Possibly why they moved as I have not heard any other users on the 'new' frequency (been on 24/7 for ages). It wouldn't surprise me if they switched over to digital radios - seems to be the way things are heading!
Bruin
Post by Bruin » 09 Oct 2015, 09:32
I Listened to them most days from here in Fairwater. Now I get binmen on there in the afternoons.
Bruin
Post by Bruin » 09 Oct 2015, 10:08
Binmen active on 165.0375 now. Certainly not as entertaining as the couriers.
Mikel
Post by Mikel » 10 Oct 2015, 10:59
Bruin wrote:Binmen active on 165.0375 now. Certainly not as entertaining as the couriers.
Yeah same here, just Binmen active on 165.0375, probably why the couriers changed frequency to 165.700. They say there's nothing worth listening to these days but I enjoy listening to the couriers.
It must be a hard job especially when the weather is bad. They take turns on the cargo bike for larger parcels, that must be hard work in itself.
The cargo bikes they use in Cardiff are similar to the ones pictured below.
