mototrbo Frequencies
Scanning radio frequencies in Wales
Smudger1309
Post by Smudger1309 » 11 Feb 2015, 20:50
hi all just brought myself an rtl dongle and as im new to this sort of scanning has any one got any frequencies for prestatyn rhyl area
RNLI is a Charity that saves lives at sea, www.rnli.org.uk
welshevo
Call Sign: 163TM995
Re: mototrbo Frequencies
Post by welshevo » 11 Feb 2015, 22:07
Welcome! to the SDR RTL world!! you wont regret it haha, as for DMR in your area, if you look around the 453.000 mhz and upwards you will can generally spot the DMR beacons and signal activity, if your using DSD+ once your locked onto a DMR freq it will then start showing data in the console window, and then talk groups etc etc and providing its not encrypted you will then hear the audio :D good luck and enjoy!
Smudger1309
Post by Smudger1309 » 11 Feb 2015, 22:21
thank you very much
so its quite easy then, also i be using the antenna that comes with it is that any good
welshevo
Call Sign: 163TM995
Post by welshevo » 11 Feb 2015, 22:36
it is easy when you got it all setup .....as for the antenna that comes with the dongle.... ive heard they are really weak at finding signals.... get yourself an external or a decent magmount antenna that covers a wideband .... 25-1500mhz normally about 35 in maplin? i use a standard mag mount antenna in my loft and that pulls in loads.....try the stick antenna you have and see what results you get... no harm in trying...
Smudger1309
Post by Smudger1309 » 11 Feb 2015, 22:39
welshevo wrote:it is easy when you got it all setup .....as for the antenna that comes with the dongle.... ive heard they are really weak at finding signals.... get yourself an external or a decent magmount antenna that covers a wideband .... 25-1500mhz normally about 35 in maplin? i use a standard mag mount antenna in my loft and that pulls in loads.....try the stick antenna you have and see what results you get... no harm in trying...
i got discone side shed for my scanner and putting vhf one up in next month or so for my other scanner, have you got link at the antenna so i no what it looks like if small maybe on roof of the shed then take it down every night
Smudger1309
Post by Smudger1309 » 11 Feb 2015, 22:48
welshevo
Call Sign: 163TM995
Post by welshevo » 11 Feb 2015, 22:57
i would use the discone for the RTL dongle.... but heres the link http://www.maplin.co.uk/p/multiscan-ant ... oCVbXw_wcB
have heard good things and bad things about this antenna, maybe do a post in scanners about antennas on here? im sure someone with more knowledge will help you out :)
Smudger1309
Post by Smudger1309 » 11 Feb 2015, 23:36
discone already set up for a scanner and all that
Smudger1309
Post by Smudger1309 » 11 Feb 2015, 23:38
is that small or does it need to go on side of building house or shed
gerald123
Post by gerald123 » 11 Feb 2015, 23:48
hi, on the same subject are there any mototrbo Frequencies frequencies for the rhondda valley south wales area..............thanks in advance...
Smudger1309
Post by Smudger1309 » 12 Feb 2015, 17:04
hi it says its needs coax lead and somtihng else, were doi get a coax lead and how do i connect it to the usb dongle
welshevo
Call Sign: 163TM995
Post by welshevo » 13 Feb 2015, 08:13
gerald123 - regarding mototrbo stuff for rhondda your better off looking around the 453.000mhz upwards in SDR# you will spot the mototrbo waveform and capacity plus beacons easily...hope this helps? if your stuck let me know and ill try to help out....
gerald123
Post by gerald123 » 14 Feb 2015, 12:28
Thanks I could do with some help.......got SDR sharp working to do the decoding.....but as yet I have seen nothing to decode on those frequencies or any others I have tried .I have tried in the day and night....it could be my location I do not know ,I get the 2 mere band 145.7500 coming in clear with good spikes showing
welshevo
Call Sign: 163TM995
Post by welshevo » 16 Feb 2015, 11:16
in SDR# can you see any beacons or blips in the waterfall.... the capacity plus systems are rife! so id be surprised if there is no Trbo up rhondda....how ever how have you got SDr# talking to DSD? virtual cable? let me know :D
welshevo
Call Sign: 163TM995
Post by welshevo » 16 Feb 2015, 12:08
another factor maybe your antenna thinking about it? what antenna are you using.... let me know!
