Starting on ssb
Guzzy
Call Sign: 26TM002
Post by Guzzy » 20 Mar 2006, 18:46
It refers to you not keying up continuously, or more to the point only using the rated power of the supply for no more than half the time.
When you listen on a 4W CB you only draw a small load on the power supply (mille Amps perhaps), but when you key up, you could be drawing 3 Amps.
Power supplies are rated as Nominal Output Current, Intermittent (or 50% duty cycle) Output Current and Peak Output Current.
  • The supply can provide it's Nominal output current (Amps) all day long.
    The supply can provide its Intermittent output current (Amps) for no more than 50% of its operating time.
    The supply can provide the Peak output current (Amps) for only brief bursts.
Hope this helps a little (sorry if it's not clear. A teacher, I am not! :-) )
If you see a spam (or abusive) post, don't 'reply' to it, don't 'quote' it, don't start a new thread discussing it.
Report it using the Image ('Report this post') button, inside the actual spam post.
troutboy
Call Sign: 163TM001
Post by troutboy » 21 Mar 2006, 10:01
The one i saw at maplins was 7 amp continuos, 10 amp 50% and 12 amp surge.
"May your tuning finger stay eager and your squelch well open"
James "troutboy" 163-TM-001
Guzzy
Call Sign: 26TM002
Post by Guzzy » 21 Mar 2006, 10:13
That sounds like it would do the job.
Unless you were tempted to add extra devices onto it.
The reason I mention this is that some people add on Linear Amplifiers and other such equipment, and then wonder why their power supply caught fire. :lol:
troutboy
Call Sign: 163TM001
Post by troutboy » 21 Mar 2006, 12:20
At the moment i am using a 3amp continuos, 5amp 50% and 7amp surge. I expect even a 5amp continuos, 7amp 50% and 9 amp surge would do the job. Because i won't be adding any other stuff
Guzzy
Call Sign: 26TM002
Post by Guzzy » 21 Mar 2006, 13:01
You never know what you might like to add in the future. It's wise to keep your options open, if you know what I mean. ;-)
troutboy
Call Sign: 163TM001
Post by troutboy » 21 Mar 2006, 14:30
yeah i kow what you mean. By the way the radio has arrived and i'm chuffed. RF gain makes all the difference brings those signals in i couldn't get on the old radio.
troutboy
Call Sign: 163TM001
Post by troutboy » 21 Mar 2006, 14:55
By the way you don't think the frequency counter draws much juice do you ?
Guzzy
Call Sign: 26TM002
Post by Guzzy » 21 Mar 2006, 15:49
I doubt it. :-)
troutboy
Call Sign: 163TM001
Post by troutboy » 21 Mar 2006, 17:49
What do you think the absolute minimum PSU i can run my new radio on full power and frequency counter is then.
5 amp continuous ?
Guzzy
Call Sign: 26TM002
Post by Guzzy » 21 Mar 2006, 18:41
Have a look at the instruction manual that came with the radio. Somewhere inside it will tell you what the maximum load is when the radio is transmitting at full power. Make sure your PSU can cope with that for 50% duty cycle.
troutboy
Call Sign: 163TM001
Post by troutboy » 22 Mar 2006, 08:45
Instruction manual ? :?
Guzzy
Call Sign: 26TM002
Post by Guzzy » 22 Mar 2006, 10:44
Time to hit google I think! :lol:
troutboy
Call Sign: 163TM001
Post by troutboy » 22 Mar 2006, 10:48
Already tried and can't find no manual
rattledrat
Post by rattledrat » 22 Mar 2006, 11:36
troutboy wrote:Instruction manual ? :?
Never buy a rig with out its manuals or even box. Think about it.
troutboy
Call Sign: 163TM001
Post by troutboy » 22 Mar 2006, 11:39
It's got a box, just no manual.
