Starting on ssb
troutboy
Call Sign: 163TM001
Post by troutboy » 18 Mar 2006, 13:47
Don't suppose you've come across any cheap rigs guzz.
I have seen a few secondhand 148's but i offered them +?60 for it and they told me they'd been offered +?130 for it. In their dreams.
Ah well good things come to those who wait.
"May your tuning finger stay eager and your squelch well open"
James "troutboy" 163-TM-001
troutboy
Call Sign: 163TM001
Post by troutboy » 19 Mar 2006, 00:33
hey guzz check out the radio i got i'll PM you the link.
TimBucknall
Post by TimBucknall » 19 Mar 2006, 10:22
Hi all,
I'm also getting started recently inherited a Marko Excalibur which sort of works, but the power output stage seems blown and its only radiating a few milliwatts, could i use some sort of amp to get it back up to 4 watts?, its such a nice looking machine and the audio is very nice i can't bear to ditch it despite its faults cheers
tim
ps: i should mention i'm crap with a soldering iron which is why i was looking for an easier fix instead of opening it up
troutboy
Call Sign: 163TM001
Post by troutboy » 19 Mar 2006, 10:50
As i'm relatively new to all of this i can't really help but you would think you could add some sort of amp to boost it, but depending on the fault it may cause problems in the long run by putting strain on the radio.
I'm sure there'll be someone on later who can help you though mate.
TimBucknall
Post by TimBucknall » 19 Mar 2006, 10:55
Thanks Mate :-)
i was also curious as to why they put 28mhz on these old multimode rigs was it just so they could sell them to hams aswell?
all the best tim
troutboy
Call Sign: 163TM001
Post by troutboy » 19 Mar 2006, 10:59
Well i'm not sure but that model may have been a 10m (28mhz) radio new and it has been opened up to work on the 11m CB band.
troutboy
Call Sign: 163TM001
Post by troutboy » 19 Mar 2006, 11:02
Although i'm not 100% but i do know most of these radios when they are new have to be opened up to work on these other bands.
TimBucknall
Post by TimBucknall » 19 Mar 2006, 11:14
thanks mate
troutboy
Call Sign: 163TM001
Post by troutboy » 19 Mar 2006, 13:54
Where was i, oh yeah Guzz mate, I've PM'd tou the radio i got, what do you think ?
troutboy
Call Sign: 163TM001
Post by troutboy » 19 Mar 2006, 16:41
So what sort of PSU do you think i'll need for that.
Guzzy
Call Sign: 26TM002
Post by Guzzy » 19 Mar 2006, 16:53
You must use a bigger amp supply than for a standard 4W CB.
Probably best to go for one that can put out 10-12 Amps continuous. It should say on the box (of the radio) what the minumum you can get away with is. (the 50% duty cycle rating on the Power supply is the absolute minimum).
If you see a spam (or abusive) post, don't 'reply' to it, don't 'quote' it, don't start a new thread discussing it.
Report it using the Image ('Report this post') button, inside the actual spam post.
troutboy
Call Sign: 163TM001
Post by troutboy » 19 Mar 2006, 17:18
Right i'll have to get a bigger psu and seeing that i can't put a bigger antenna up i'll have to make do with my 18ft dipole.
So you don't reckon much to these pre-amps Guzz mate ?
Guzzy
Call Sign: 26TM002
Post by Guzzy » 19 Mar 2006, 17:36
No.
troutboy
Call Sign: 163TM001
Post by troutboy » 19 Mar 2006, 17:47
So with keeping this antenna you reckon not to bother getting a pre amp. Do they make much difference ?
Guzzy
Call Sign: 26TM002
Post by Guzzy » 19 Mar 2006, 19:09
If you have a good antenna in a good location (high up with good line of sight and away from obstructions) then using a good quality pre-amp, inline close to the antenna (mast head style pre-amp) then, yes it can help with weak signals.
If you are in a poor location or your antenna is surrounded by buildings or other obstructions then all you are doing is amplifiying all the crud in the local area.
