5/8 wave venom type silver rod improvements ?
original45
Call Sign: 45
Re: 5/8 wave venom type silver rod improvements ?
Post by original45 » 19 May 2019, 20:29
On my antron I used electrical tape them self amalg tape over top as it is often v expensive.
One type I have only lasted a few years on something I covered. But it was from China very rubbery stretches loads.
108EH002
Post by 108EH002 » 20 May 2019, 08:38
' Electrical tape will loose its stickiness and unravel Collector ^^ = just use a white cable tie to stop the tape unravelling,and cut off the excess when tied,keeping it a tidy install ;)
- 27.555 USB +
original45
Call Sign: 45
Post by original45 » 20 May 2019, 09:18
're bolting through the antenna tubes at joints, does anyone feel two bolts straight through would be any better than 4 self tapping stainless screws .
Post by The Collector » 20 May 2019, 16:47
Screws can work loose with the too-ing and fro-ing in the wind. Taping over them would help a bit, or try using some threadlock glue on them.
If bolting, use stainless fixings if possible and use either anti-vibration washers or nyloc nuts ;)
original45
Call Sign: 45
Post by original45 » 20 May 2019, 16:55
Cool .
Will order stainless bolts and anti vibration washers with nylocs.
Unit 148 Mobile
Call Sign: G4ZOW
Post by Unit 148 Mobile » 26 May 2019, 05:00
45,
I've personally never added radials to a 5/8th's but did have a Hy-Gain Golden Penetrator 5/8th's back in the day. The radials were horizontal and I believe they improved the low take-off angle which is the main benefit the 5/8th's has over a 1/2 wave. I do not know if the radials help with impedance matching.
Unit 148
