magnum s-9
- Call Sign: BPO6O
magnum s-9
hi Chaps
got a Magnum s9 thinking ii could get uk fm on it bit sick you cant with out it having a convertion any one on here had one done its on 10 meters so what to do
- astradyne
Re: magnum s-9
Simply turn the course tune until the frequency display ends in 12 (For 19 it would be 27.7812).
Modding these for UK legal l - 40 readout? Never heard of it being done, but seems completely unnecessary with the radio already having all the frequencies built in.
- Call Sign: 108TM127
Re: magnum s-9
If I were you just have it open all the way through , I had one and never fitted anything else to it , after all who uses an echo ect on 10 Mtr
- Call Sign: BPO6O
Re: magnum s-9
have turned the course but still can not get it to read 27.7812 . on fm it reads 27.7825
Re: magnum s-9
The radio might need realigned then . It should get more that +/- 3khz swing .
Re: magnum s-9
Have you tried getting on frequency from the closest channel below and above the frequency you want? The coarse may not be enough to go down from above, but might be enough to go up from below if you know what I mean.
If it won't drop onto frequency and if you don't want to fork out for a service and posyage each way, perhaps just keep it for proper 10m radio stuff and swap to a dedicated ukfm £5 rig when wanting to use the muppets.
Or...I'll swap you an Economy 40 radio for it
Re: magnum s-9
So will I , plus a £1
- astradyne
Re: magnum s-9
I was thinking the same thing Sammy. All of the S-9's I've seen are easily capable of reaching the UK frequencies by turning the coarse control anti clockwise. Yet, for some reason, this one has a deficit of 1.3khz (Even more when you consider it should reach the UK offset at around 9 O'clock).cb4ever104 wrote: ↑05 Jan 2019, 16:49 The radio might need realigned then . It should get more that +/- 3khz swing .
Perhaps he should give Nick a shout regarding a good tune up because it just doesn't sound right.
- Call Sign: BPO6O
Re: magnum s-9
Happy man just got radio back from NICK all singing and dancing he as put is magic fingers in like a new radio now
- astradyne
Re: magnum s-9
Excellent news. Did Nick give any feedback on what the issue was?
- Call Sign: BPO6O
Re: magnum s-9
radio tuned 10kcs to high vco warbling badly some one tried to do a mosfset but did it badly then he went trough it all top job
