President james. UK40?
Mudslinger
Post by Mudslinger »
I have got myself a President James as part of a joblot, and it seems to work.
The problem is at the moment it is 6 bands AM/FM and there is no one to talk to...
Does anyone know the code sequence to get it onto UK40? That is assuming it can be done?
Many thanks
163TM847
Re: President james. UK40?
Post by 163TM847 »
Make sense to you ?
viewtopic.php?t=47541
President James on UK40 press power on off on again pressing PA and dimmer same time release power keep pressing PA amd dimmer release when code flashes 4 times and goes out press mode press program 4 times then power.
Post by The Collector »
I tried that on mine and found I seemed to need more fingers than I actually had ;)
I gave up and flogged it in the end as to go through all that faffing around, simply wasn't worth the hassle.
I've heard they're a lot worse than the George.
Mudslinger
Black Spirit wrote: 24 Nov 2018, 23:18 Make sense to you ?
Cheers Nick, It sort of makes sense. I will try it later.
The radio is unlikely to be a keeper but it would be good to try it.
Mudslinger
It worked, thank you Nick and was easier than I thought it would be.
